Salta al contenuto principale
Supersonic Matrix SC-91MID Screen Replacement
Cosa ti serve
  1. Supersonic Matrix SC-91MID Screen Replacement, Screen: passo 1, immagine 1 di 2 Supersonic Matrix SC-91MID Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Place the plastic opening tool between the screen and the main component and pry open between the two. Once removed place the main component in a safe place and continue working on the screen section.
    • Be aware of the ribbon cables when removing the display screen from the main component.
    Chiedi a FixBot
    Aggiungi Commento
  2. Supersonic Matrix SC-91MID Screen Replacement: passo 2, immagine 1 di 3 Supersonic Matrix SC-91MID Screen Replacement: passo 2, immagine 2 di 3 Supersonic Matrix SC-91MID Screen Replacement: passo 2, immagine 3 di 3
    • Place the plastic opening tool between the metal screen plate and the black front casing.
    • There are small clips where the plastic opening tool can be placed to help pry the screen from the casing.
    Chiedi a FixBot
    Aggiungi Commento
  3. Supersonic Matrix SC-91MID Screen Replacement: passo 3, immagine 1 di 3 Supersonic Matrix SC-91MID Screen Replacement: passo 3, immagine 2 di 3 Supersonic Matrix SC-91MID Screen Replacement: passo 3, immagine 3 di 3
    • Continue to slide the opening tool along the length of the casing until there is a clear separation between the screen and the cover (as shown in the third image).
    Chiedi a FixBot
    Aggiungi Commento
  4. Supersonic Matrix SC-91MID Screen Replacement: passo 4, immagine 1 di 1
    • Once there is a clearing, carefully remove the screen from the black cover. You now have separated the screen from the tablet device and and are now ready to replace screen.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Norikuni Nishikawa
Membro da: 03/31/18
139 Reputazione
Una guida realizzata
IUPUI, Team S1-G1, Wilson Spring 2018 Membro di IUPUI, Team S1-G1, Wilson Spring 2018
IUPUI-WILSON-S18S1G1
5 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 35
Tutti i Tempi: 592
