Salta al contenuto principale
Super Nintendo Power Switch Replacement
Cosa ti serve
  1. Super Nintendo Power Switch Replacement, Outer Case: passo 1, immagine 1 di 1
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  2. Super Nintendo Power Switch Replacement: passo 2, immagine 1 di 3 Super Nintendo Power Switch Replacement: passo 2, immagine 2 di 3 Super Nintendo Power Switch Replacement: passo 2, immagine 3 di 3
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
    Chiedi a FixBot
    Aggiungi Commento
  3. Super Nintendo Power Switch Replacement, Power Switch: passo 3, immagine 1 di 1
    • Remove the two 11.7 mm Phillips #2 screws connecting the power switch to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  4. Super Nintendo Power Switch Replacement: passo 4, immagine 1 di 2 Super Nintendo Power Switch Replacement: passo 4, immagine 2 di 2
    • The power switch is connected to the motherboard near the top left of the console.
    • Carefully pull the connector from its socket on the motherboard. You may need to wiggle it out as you pull.
    • Do not detach the connector by pulling on the wires. This could damage the wires or the socket.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 16 persone hanno completato questa guida.
Cal Poly, Team 4-47, Amido Fall 2010 Membro di Cal Poly, Team 4-47, Amido Fall 2010
CPSU-AMIDO-F10S4G47
4 Membri
25 guide realizzate
2Commenti sulla guida
Any tips on how to tell if it's the power switch that needs replacing vs something else?
TopShopGames - Rispondi Condividi
Look at it for any signs of physical damage, if you don't see any noticeable issues that you can fix then you can try cutting the two wires stripping off the ends of them, and very carefully touching the wires together while its plugged in. BE EXTREMELY CAREFUL WHILE DOING THIS DO NOT TOUCH THE EXPOSED WIRE. If you notice it turn on, immediately stop touching the wires together and unplug the console. This means that the switch itself is broken. If it doesn't turn on, stop touching the wire together and unplug the console. This means that it's likely a power cable issue.
Anders Hoff - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 35
Ultimi 30 giorni: 137
Tutti i Tempi: 26,665
