Introduzione
Follow this guide to replace the right trigger (R2) in your Steam Controller (2nd Gen, 2026).
If your Steam Controller's right trigger (R2) feels loose, sticks during use, or registers inputs incorrectly, it might need to be replaced.
Problems with incorrect trigger inputs may indicate an issue with the main board—specifically, the trigger's hall effect sensor. If you suspect that's the case, follow this guide to replace the main board.
Cosa ti serve
Unplug all cables and accessories from the controller, including the Steam Controller Puck.
Attrezzo utilizzato in questo passaggio:TR6 Torx Security Screwdriver$5.99
Use a T6 Torx screwdriver to remove the seven screws securing the back cover.
Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from.
Use a T6 Torx screwdriver to remove the four 7.4 mm‑long screws securing the battery mounting bracket.
With one hand, fully depress the right trigger.
With your free hand, use tweezers to pull the hinge pin straight out and remove it.
Remove the right trigger.
If the spring stayed on its post, leave it in place.
