Salta al contenuto principale
Spy Net Ultra Vision Goggles Infrared Lights Replacement
Cosa ti serve
  1. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Open the Device: passo 1, immagine 1 di 1
    • Remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
    • Pry open the shell using the plastic opening tools if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
    Chiedi a FixBot
  2. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: passo 2, immagine 1 di 3 Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: passo 2, immagine 2 di 3 Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: passo 2, immagine 3 di 3
    • Find the infrared light assemblies, which are located at the front end of the device on either side of the lens.
    • The process is the same regardless of which light you are replacing.
    • Lift the light assembly away from the rest of the device.
    Chiedi a FixBot
  3. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Open the Light Assembly: passo 3, immagine 1 di 1
    • Use the plastic opening tools to pry open the light assembly.
    Chiedi a FixBot
  4. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Disconnect the Lights: passo 4, immagine 1 di 1
    • Use the soldering iron and desoldering braid to de-solder the wires from the lights.
    • Check out This Guide for tips on soldering and de-soldering connections.
    Chiedi a FixBot
Conclusione
Travis Kempf
Membro da: 09/22/14
198 Reputazione
Una guida realizzata
USF Tampa, Team 4-5, Brown Fall 2014 Membro di USF Tampa, Team 4-5, Brown Fall 2014
USFT-BROWN-F14S4G5
3 Membri
6 guide realizzate
1Commento della guida
thanks for the help
vincentarriesgado - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 56
Tutti i Tempi: 1,280
