Salta al contenuto principale
Spin Master Boxer Wheel Gears Replacement
Cosa ti serve
  1. Spin Master Boxer Wheel Gears Replacement, Robot Screen: passo 1, immagine 1 di 1
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
    Chiedi a FixBot
    Aggiungi Commento
  2. Spin Master Boxer Wheel Gears Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
    Chiedi a FixBot
    Aggiungi Commento
  3. Spin Master Boxer Wheel Gears Replacement: passo 3, immagine 1 di 1
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
    Chiedi a FixBot
    Aggiungi Commento
  4. Spin Master Boxer Wheel Gears Replacement: passo 4, immagine 1 di 2 Spin Master Boxer Wheel Gears Replacement: passo 4, immagine 2 di 2
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
    Chiedi a FixBot
    Aggiungi Commento
  5. Spin Master Boxer Wheel Gears Replacement: passo 5, immagine 1 di 1
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
    Chiedi a FixBot
    Aggiungi Commento
  6. Spin Master Boxer Wheel Gears Replacement, Robot Wheel Gears: passo 6, immagine 1 di 1
    • Place robot on back so that the sensors are facing up.
    Chiedi a FixBot
    Aggiungi Commento
  7. Spin Master Boxer Wheel Gears Replacement: passo 7, immagine 1 di 2 Spin Master Boxer Wheel Gears Replacement: passo 7, immagine 2 di 2
    • Gently separate the left set of wheels from the inner portion of the circuit board, by gripping the wheels and pulling them away from main body of robot.
    • There are wires attached to each set of wheels, so be careful not to rip them apart.
    • Repeat the process for the right set of wheels.
    Chiedi a FixBot
    Aggiungi Commento
  8. Spin Master Boxer Wheel Gears Replacement: passo 8, immagine 1 di 2 Spin Master Boxer Wheel Gears Replacement: passo 8, immagine 2 di 2
    • Use the Phillips #00 Screwdriver to remove the 3mm screw that connect the black wheels to the gears.
    • You will have to go through the black wheel to unscrew some of the screws.
    Chiedi a FixBot
    Aggiungi Commento
  9. Spin Master Boxer Wheel Gears Replacement: passo 9, immagine 1 di 3 Spin Master Boxer Wheel Gears Replacement: passo 9, immagine 2 di 3 Spin Master Boxer Wheel Gears Replacement: passo 9, immagine 3 di 3
    • Grip wheel, and gently pull up, to separate white gear casing into its front and back panel.
    Chiedi a FixBot
    Aggiungi Commento
  10. Spin Master Boxer Wheel Gears Replacement: passo 10, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Using tweezers, grip defective gear, and pull up and out of gear system to replace.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S1-G1, Maness Spring 2019 Membro di Cal Poly, Team S1-G1, Maness Spring 2019
CPSU-MANESS-S19S1G1
4 Membri
10 guide realizzate
3Commenti sulla guida
This is super useful guide and picture are clear for the steps. Will be excellent to know where to buy these gears replacements?
Javier Perez - Rispondi Condividi
Hello. Thé motor seems to be broken. Do you Knowles ils spec to buy à New one.
Sorry, im french...
Tanks.
Jerome Carbonneaux - Rispondi Condividi
Do you know its spec to buy a new one?
Realy sorry...
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 9
Ultimi 30 giorni: 55
Tutti i Tempi: 4,473
