Salta al contenuto principale
Sony Xperia Z1 Compact Rear Camera Replacement
Cosa ti serve
  1. Sony Xperia Z1 Compact Rear Camera Replacement, Back Cover: passo 1, immagine 1 di 1
    • Heat along the edges of the back cover using a heat gun to soften the glue.
    Chiedi a FixBot
    Aggiungi Commento
  2. Sony Xperia Z1 Compact Rear Camera Replacement: passo 2, immagine 1 di 1
    • Attach the small suction cup to the back cover near the bottom of the phone.
    • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. Sony Xperia Z1 Compact Rear Camera Replacement: passo 3, immagine 1 di 2 Sony Xperia Z1 Compact Rear Camera Replacement: passo 3, immagine 2 di 2
    • Move the spudger around the edge of the back cover to separate it from the black adhesive.
    • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
    Chiedi a FixBot
    Aggiungi Commento
  4. Sony Xperia Z1 Compact Rear Camera Replacement, Battery: passo 4, immagine 1 di 2 Sony Xperia Z1 Compact Rear Camera Replacement, Battery: passo 4, immagine 2 di 2
    • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
    Chiedi a FixBot
    Aggiungi Commento
  5. Sony Xperia Z1 Compact Rear Camera Replacement: passo 5, immagine 1 di 2 Sony Xperia Z1 Compact Rear Camera Replacement: passo 5, immagine 2 di 2
    • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  6. Sony Xperia Z1 Compact Rear Camera Replacement: passo 6, immagine 1 di 1
    • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
    Chiedi a FixBot
    Aggiungi Commento
  7. Sony Xperia Z1 Compact Rear Camera Replacement: passo 7, immagine 1 di 1
    • Remove the battery from the device
    Chiedi a FixBot
    Aggiungi Commento
  8. Sony Xperia Z1 Compact Rear Camera Replacement, External Speaker: passo 8, immagine 1 di 2 Sony Xperia Z1 Compact Rear Camera Replacement, External Speaker: passo 8, immagine 2 di 2
    • Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  9. Sony Xperia Z1 Compact Rear Camera Replacement: passo 9, immagine 1 di 3 Sony Xperia Z1 Compact Rear Camera Replacement: passo 9, immagine 2 di 3 Sony Xperia Z1 Compact Rear Camera Replacement: passo 9, immagine 3 di 3
    • Wedge the plastic opening tool under the back frame. Move the plastic opening tool around the entire frame to separate it from the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  10. Sony Xperia Z1 Compact Rear Camera Replacement: passo 10, immagine 1 di 1
    • Remove the back frame.
    Chiedi a FixBot
    Aggiungi Commento
  11. Sony Xperia Z1 Compact Rear Camera Replacement: passo 11, immagine 1 di 2 Sony Xperia Z1 Compact Rear Camera Replacement: passo 11, immagine 2 di 2
    • Wedge the spudger underneath the external speaker. Pull up on the external speaker using the spudger.
    Chiedi a FixBot
    Aggiungi Commento
  12. Sony Xperia Z1 Compact Rear Camera Replacement: passo 12, immagine 1 di 2 Sony Xperia Z1 Compact Rear Camera Replacement: passo 12, immagine 2 di 2
    • Remove the external speaker.
    Chiedi a FixBot
    Aggiungi Commento
  13. Sony Xperia Z1 Compact Rear Camera Replacement, Motherboard: passo 13, immagine 1 di 2 Sony Xperia Z1 Compact Rear Camera Replacement, Motherboard: passo 13, immagine 2 di 2
    • Remove the square rubber gasket from the camera using the plastic spudger.
    Chiedi a FixBot
    Aggiungi Commento
  14. Sony Xperia Z1 Compact Rear Camera Replacement: passo 14, immagine 1 di 2 Sony Xperia Z1 Compact Rear Camera Replacement: passo 14, immagine 2 di 2
    • Remove the black plastic corner still holding in the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  15. Sony Xperia Z1 Compact Rear Camera Replacement: passo 15, immagine 1 di 3 Sony Xperia Z1 Compact Rear Camera Replacement: passo 15, immagine 2 di 3 Sony Xperia Z1 Compact Rear Camera Replacement: passo 15, immagine 3 di 3
    • Carefully pry up on the four sides of the motherboard using the plastic spudger til it separates from the base of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  16. Sony Xperia Z1 Compact Rear Camera Replacement: passo 16, immagine 1 di 3 Sony Xperia Z1 Compact Rear Camera Replacement: passo 16, immagine 2 di 3 Sony Xperia Z1 Compact Rear Camera Replacement: passo 16, immagine 3 di 3
    • Remove the motherboard from the device.
    • There may be a small yellow adhesive underneath the motherboard still holding it in. Slide the tip of the spudger through it to sever it.
    Chiedi a FixBot
    Aggiungi Commento
  17. Sony Xperia Z1 Compact Rear Camera Replacement, Rear Camera: passo 17, immagine 1 di 2 Sony Xperia Z1 Compact Rear Camera Replacement, Rear Camera: passo 17, immagine 2 di 2
    • Disconnect the camera from the motherboard using a spudger.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
1Commento della guida
The trouble is that the headphones jack and the monitor cables are unplugged when removing the motherboard and I do not think it is possible to plug them back in from the back side of the phone. I think the monitor needs to be removed for them to be plugged from the front.
natuk - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 39
Tutti i Tempi: 1,261
