Salta al contenuto principale
Sony Xperia XA1 Battery Replacement
Cosa ti serve
  1. Sony Xperia XA1 Battery Replacement, Phone Back Cover: passo 1, immagine 1 di 3 Sony Xperia XA1 Battery Replacement, Phone Back Cover: passo 1, immagine 2 di 3 Sony Xperia XA1 Battery Replacement, Phone Back Cover: passo 1, immagine 3 di 3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Battery Replacement, Battery: passo 2, immagine 1 di 2 Sony Xperia XA1 Battery Replacement, Battery: passo 2, immagine 2 di 2
    • Disconnect the battery from the motherboard using an opening tool or spudger.
  3. Sony Xperia XA1 Battery Replacement: passo 3, immagine 1 di 3 Sony Xperia XA1 Battery Replacement: passo 3, immagine 2 di 3 Sony Xperia XA1 Battery Replacement: passo 3, immagine 3 di 3
    • Lift the black tabs on either side of the battery
  4. Sony Xperia XA1 Battery Replacement: passo 4, immagine 1 di 3 Sony Xperia XA1 Battery Replacement: passo 4, immagine 2 di 3 Sony Xperia XA1 Battery Replacement: passo 4, immagine 3 di 3
    • Lift the pull tab at the bottom to unseat the battery.
    • After unseating the battery with the pull tab, lift it out of the case.
    • Use caution handling the battery. It is extremely delicate.
  5. Sony Xperia XA1 Battery Replacement: passo 5, immagine 1 di 2 Sony Xperia XA1 Battery Replacement: passo 5, immagine 2 di 2
    • Remove the battery entirely.
    • Do not dispose of your old battery in a regular trash can. Please bring your phone battery to a local home depot, best buy, or staples for safe disposal and recycling in the US and Canada. Other places in the world, please contact your local recycling centers.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 35
Tutti i Tempi: 433
