Salta al contenuto principale
Sony Xperia M2 Touchscreen Replacement
Cosa ti serve
  1. Sony Xperia M2 Touchscreen Replacement, Rear Cover: passo 1, immagine 1 di 3 Sony Xperia M2 Touchscreen Replacement, Rear Cover: passo 1, immagine 2 di 3 Sony Xperia M2 Touchscreen Replacement, Rear Cover: passo 1, immagine 3 di 3
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Cover is plastic.
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one if your spare part has come without double sided adhesive tape.
    Chiedi a FixBot
    Aggiungi Commento
  2. Sony Xperia M2 Touchscreen Replacement, Battery: passo 2, immagine 1 di 3 Sony Xperia M2 Touchscreen Replacement, Battery: passo 2, immagine 2 di 3 Sony Xperia M2 Touchscreen Replacement, Battery: passo 2, immagine 3 di 3
    • Disconnect the Battery Cable.
    • The battery is stuck to the phone fame. Use the white tape to remove it.
    • Li-Polymer Battery, 2230 mAh
    • Part number: LIS1551ERPC
    • Please SUBSCRIBE to my channel ツ
    Chiedi a FixBot
    Aggiungi Commento
  3. Sony Xperia M2 Touchscreen Replacement, Logic Board: passo 3, immagine 1 di 2 Sony Xperia M2 Touchscreen Replacement, Logic Board: passo 3, immagine 2 di 2
    • Remove the SIM and the memory cards.
    • Remove x4 T5 Torx Corner screws & x2 T5 Torx Screws on the Board
    Chiedi a FixBot
    Aggiungi Commento
  4. Sony Xperia M2 Touchscreen Replacement: passo 4, immagine 1 di 1
    • Disconnect one by one:
    • Touchscreen flex cable
    • Proximity sensor flex cable
    • Power on, Volume buttons cable
    • SIM & Micro SD flex cable
    • Coaxial antenna cable
    Chiedi a FixBot
    Aggiungi Commento
  5. Sony Xperia M2 Touchscreen Replacement: passo 5, immagine 1 di 2 Sony Xperia M2 Touchscreen Replacement: passo 5, immagine 2 di 2
    • Disconnect the LCD Display flex cable. The connector is on the other side of the board, under the Power/Volume buttons flex cable connector.
    • Put one plastic spudger between the Logic board and the Main frame.
    Chiedi a FixBot
    Aggiungi Commento
  6. Sony Xperia M2 Touchscreen Replacement: passo 6, immagine 1 di 3 Sony Xperia M2 Touchscreen Replacement: passo 6, immagine 2 di 3 Sony Xperia M2 Touchscreen Replacement: passo 6, immagine 3 di 3
    • Step one: move aside less the left side of the board - down.
    • Step two: the left side of the Logic board must go out of the main frame.
    • For this manipulation use only plastic tools.
    Chiedi a FixBot
    Aggiungi Commento
  7. Sony Xperia M2 Touchscreen Replacement, LCD Display, Touchscreen / Glass / Digitizer: passo 7, immagine 1 di 3 Sony Xperia M2 Touchscreen Replacement, LCD Display, Touchscreen / Glass / Digitizer: passo 7, immagine 2 di 3 Sony Xperia M2 Touchscreen Replacement, LCD Display, Touchscreen / Glass / Digitizer: passo 7, immagine 3 di 3
    • Let's first test the new spare parts.
    Chiedi a FixBot
    Aggiungi Commento
  8. Sony Xperia M2 Touchscreen Replacement: passo 8, immagine 1 di 3 Sony Xperia M2 Touchscreen Replacement: passo 8, immagine 2 di 3 Sony Xperia M2 Touchscreen Replacement: passo 8, immagine 3 di 3
    • Use a scotch tape for the broken glass.
    • Unstuck the LCD Display flex cable from the Main frame.
    • Now preheat the glass before removing. This will soften the adhesive and will make separating more easy.
    • You can use a hairdryer.
    Chiedi a FixBot
    Aggiungi Commento
  9. Sony Xperia M2 Touchscreen Replacement: passo 9, immagine 1 di 3 Sony Xperia M2 Touchscreen Replacement: passo 9, immagine 2 di 3 Sony Xperia M2 Touchscreen Replacement: passo 9, immagine 3 di 3
    • With a cutter, make a room for a plastic tool, then continue with separating the Touchscreen & LCD Display from the frame.
    Chiedi a FixBot
    Aggiungi Commento
  10. Sony Xperia M2 Touchscreen Replacement: passo 10, immagine 1 di 3 Sony Xperia M2 Touchscreen Replacement: passo 10, immagine 2 di 3 Sony Xperia M2 Touchscreen Replacement: passo 10, immagine 3 di 3
    • This is the Display Assembly.
    • The LCD Display and the Touchscreen are not firmly bonded, while some other other models.
    Chiedi a FixBot
    Aggiungi Commento
  11. Sony Xperia M2 Touchscreen Replacement: passo 11, immagine 1 di 3 Sony Xperia M2 Touchscreen Replacement: passo 11, immagine 2 di 3 Sony Xperia M2 Touchscreen Replacement: passo 11, immagine 3 di 3
    • If your Touchscreen or LCD Display is OK, separate them carefully.
    • In our situation, both of them are broken.
    Chiedi a FixBot
    Aggiungi Commento
  12. Sony Xperia M2 Touchscreen Replacement: passo 12, immagine 1 di 3 Sony Xperia M2 Touchscreen Replacement: passo 12, immagine 2 di 3 Sony Xperia M2 Touchscreen Replacement: passo 12, immagine 3 di 3
    • Clean the frame from the remains of tape.
    • Install the LCD Display and the flex cable on its correct place.
    Chiedi a FixBot
    Aggiungi Commento
  13. Sony Xperia M2 Touchscreen Replacement: passo 13, immagine 1 di 3 Sony Xperia M2 Touchscreen Replacement: passo 13, immagine 2 di 3 Sony Xperia M2 Touchscreen Replacement: passo 13, immagine 3 di 3
    • We could not find adhesive sticker for this model, so We used universal adhesive tape 3M - 3 mm.
    • Don't forget to remove protectors from the LCD Display and from the inner side of the Touchscreen.
    Chiedi a FixBot
    Aggiungi Commento
  14. Sony Xperia M2 Touchscreen Replacement: passo 14, immagine 1 di 3 Sony Xperia M2 Touchscreen Replacement: passo 14, immagine 2 di 3 Sony Xperia M2 Touchscreen Replacement: passo 14, immagine 3 di 3
    • When finishing the assembly of the inner parts, use same technic to install the Back cover.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 40 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
197.270 Reputazione
330 guide realizzate
Master Techs Membro di Master Techs
Community
334 Membri
1.701 guide realizzate
18Commenti sulla guida
I successfuly repaired my Phone. The only Problem i had was that i proke the LCD as i was trying to Open the Phone. So take care when you open the phone an be very carefull!
Thank you Ifixit for this guide!
Fabian - Rispondi Condividi
Followed Guide & completed without any errors. Also Step 2 "remove x4 screws" There's also x2 Screws on the board that needs removing.
Also The touch screen isn't exactly glued to the screen so does come of pretty easy but be very careful when using spudger to remove the glass as you could easily prod the touch screen. Apart from that thanks for the Guide it went well.
WILSON3000 - Rispondi Condividi
Hi there. Thanks for the leaflet with the links that I got with my purchase. Things went really well, except for one thing. Not sure if you can help, but it would be great if you can.
Everything is connected and assembled, although not bonded yet. The problem I have is the touch screen buttons at the bottom of the screen (return/back, home, task navigation) are completely unresponsive. Is there anything you could advice to help please.
It might be worth knowing that with the phone in landscape (rather than portrait) the buttons seem to work, maybe suggesting that there is something at the bottom of the screen that's not quite right.
Thank you in advance of any response.
spooksfacebook - Rispondi Condividi
bro you change whole part touch digitizer + lcd ???
shehroz - Rispondi Condividi
I changed the broken touchscreen today... with success, except that during the operation, I broke the LCD! (I did not read the comments first!!!) Indeed, the screen was broken in many parts and as I wanted to unpaste some of the rather small parts (1-2cm wide), they pressed on the screen and broke it. It is not visible when switched off, but I could check that some broken parts correspond to the shape of some shards of glass when I switched it on and realize that I broke it.
A comment that might be useful: when you assemble again the microphone part, extend maximally the door of the SIM and the microSD, otherwise you may have difficulties to place it back, and do not forget the connector of the proximity detector.
Good luck!
Nicohoho - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 16
Ultimi 30 giorni: 55
Tutti i Tempi: 88,790
