Salta al contenuto principale
Sony VAIO VPCEE26FX RAM Replacement
Cosa ti serve
    1. Sony VAIO VPCEE26FX RAM Replacement, Battery: passo 1, immagine 1 di 2 Sony VAIO VPCEE26FX RAM Replacement, Battery: passo 1, immagine 2 di 2
      • Ensure that the laptop is powered off before disconnecting the battery.
      • Flip the laptop over so the underside of the laptop is facing up.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony VAIO VPCEE26FX RAM Replacement: passo 2, immagine 1 di 2 Sony VAIO VPCEE26FX RAM Replacement: passo 2, immagine 2 di 2
      • Slide the two tabs towards each other until the battery disconnects slightly from its position.
      • Carefully lift the battery out of its position away from the laptop.
      • The battery is not pictured here, since it is missing from this particular device.
      Chiedi a FixBot
      Aggiungi Commento
    1. Sony VAIO VPCEE26FX RAM Replacement, RAM: passo 3, immagine 1 di 1
      • Using a JIS #0 screwdriver, loosen the captive screw attached to the RAM cover.
      • This screw will not come out all the way, but will remain attached to the cover instead.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony VAIO VPCEE26FX RAM Replacement: passo 4, immagine 1 di 1
      • Remove the cover which will reveal the two RAM sticks.
      Chiedi a FixBot
      Aggiungi Commento
    3. Sony VAIO VPCEE26FX RAM Replacement: passo 5, immagine 1 di 3 Sony VAIO VPCEE26FX RAM Replacement: passo 5, immagine 2 di 3 Sony VAIO VPCEE26FX RAM Replacement: passo 5, immagine 3 di 3
      • Push the two tabs holding the RAM sticks in place, away from each other.
      • The first RAM stick will pop up out of place. Remove it away from its position.
      Chiedi a FixBot
      Aggiungi Commento
    4. Sony VAIO VPCEE26FX RAM Replacement: passo 6, immagine 1 di 3 Sony VAIO VPCEE26FX RAM Replacement: passo 6, immagine 2 di 3 Sony VAIO VPCEE26FX RAM Replacement: passo 6, immagine 3 di 3
      • Push the two tabs holding the second RAM stick in, away from each other.
      • The second RAM stick will pop up out of place. Remove it away from its position.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 9
Ultimi 30 giorni: 24
Tutti i Tempi: 1,905
