Salta al contenuto principale
Sony Reader Touch Edition PRS-600 Screen Replacement
Cosa ti serve
  1. Sony Reader Touch Edition PRS-600 Screen Replacement, Back Panel: passo 1, immagine 1 di 1
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
    Chiedi a FixBot
    Aggiungi Commento
  2. Sony Reader Touch Edition PRS-600 Screen Replacement: passo 2, immagine 1 di 1
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
    Chiedi a FixBot
    Aggiungi Commento
  3. Sony Reader Touch Edition PRS-600 Screen Replacement: passo 3, immagine 1 di 1
    • This is what the device should look like once the back cover panel has been removed.
    Chiedi a FixBot
    Aggiungi Commento
  4. Sony Reader Touch Edition PRS-600 Screen Replacement, Battery: passo 4, immagine 1 di 1
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
    Chiedi a FixBot
    Aggiungi Commento
  5. Sony Reader Touch Edition PRS-600 Screen Replacement: passo 5, immagine 1 di 1
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
    Chiedi a FixBot
    Aggiungi Commento
  6. Sony Reader Touch Edition PRS-600 Screen Replacement, Power Button: passo 6, immagine 1 di 1
    • Remove the stylus from the device.
    Chiedi a FixBot
    Aggiungi Commento
  7. Sony Reader Touch Edition PRS-600 Screen Replacement: passo 7, immagine 1 di 3 Sony Reader Touch Edition PRS-600 Screen Replacement: passo 7, immagine 2 di 3 Sony Reader Touch Edition PRS-600 Screen Replacement: passo 7, immagine 3 di 3
    • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
    • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
    • Pry apart off the top panel of the device.
    Chiedi a FixBot
    Aggiungi Commento
  8. Sony Reader Touch Edition PRS-600 Screen Replacement, Side and Bottom Panel: passo 8, immagine 1 di 2 Sony Reader Touch Edition PRS-600 Screen Replacement, Side and Bottom Panel: passo 8, immagine 2 di 2
    • Using a Phillips head screwdriver, remove the two 1.4 mm screws from the bottom panel of the device.
    • Using the same screwdriver, remove the 1.4 mm screw that is located on the back of the device.
    Chiedi a FixBot
    Aggiungi Commento
  9. Sony Reader Touch Edition PRS-600 Screen Replacement: passo 9, immagine 1 di 2 Sony Reader Touch Edition PRS-600 Screen Replacement: passo 9, immagine 2 di 2
    • Pull the panel away from the device. You may have to use the flat end of the spudger to remove the side portion of the panel because it will be glued in place.
    Chiedi a FixBot
    Aggiungi Commento
  10. Sony Reader Touch Edition PRS-600 Screen Replacement, Inner Casing: passo 10, immagine 1 di 1
    • Using a screwdriver remove the four 1.4 mm screws that are holding the black plastic casing in place.
    Chiedi a FixBot
    Aggiungi Commento
  11. Sony Reader Touch Edition PRS-600 Screen Replacement: passo 11, immagine 1 di 1
    • Pry open the black casing to access the screw that is holding down the battery holder.
    • Remove the one 1.4 mm screw that is holding down the battery holder located under black casing.
    • Lift the black inner casing and the battery holder out of the device.
    • The battery holder and the black inner casing are connected by a thin strip of copper. There may be glue holding the black inner casing in place.
    Chiedi a FixBot
    Aggiungi Commento
  12. Sony Reader Touch Edition PRS-600 Screen Replacement, Motherboard: passo 12, immagine 1 di 1
    • Using a Phillips head screwdriver, remove the one 1.4 mm screw holding in the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  13. Sony Reader Touch Edition PRS-600 Screen Replacement: passo 13, immagine 1 di 2 Sony Reader Touch Edition PRS-600 Screen Replacement: passo 13, immagine 2 di 2
    • Using the flat end of the spudger, flip up the 4 latches holding down the thin, orange strips that connect the motherboard to the screen, audio/AC adapter/micro USB ports, and SD card/PRODuo ports.
    • To disconnect the the screen, audio/AC adapter/micro USB ports, and SD card/PRODuo ports pull each orange slip away from their corresponding latch.
    Chiedi a FixBot
    Aggiungi Commento
  14. Sony Reader Touch Edition PRS-600 Screen Replacement: passo 14, immagine 1 di 2 Sony Reader Touch Edition PRS-600 Screen Replacement: passo 14, immagine 2 di 2
    • Lift the end of the motherboard closest to the memory cards and pull out.
    Chiedi a FixBot
    Aggiungi Commento
  15. Sony Reader Touch Edition PRS-600 Screen Replacement, Screen: passo 15, immagine 1 di 2 Sony Reader Touch Edition PRS-600 Screen Replacement, Screen: passo 15, immagine 2 di 2
    • Using a Phillips head screwdriver, remove the three 1.4 mm screws located on the SD/memory card holder.
    • Remove the SD/memory card holder from the device.
    Chiedi a FixBot
    Aggiungi Commento
  16. Sony Reader Touch Edition PRS-600 Screen Replacement: passo 16, immagine 1 di 1
    • Using the Phillips head screwdriver, remove the two 1.4 mm screws in the screen at the bottom of the device that are usually covered by the power switch panel.
    Chiedi a FixBot
    Aggiungi Commento
  17. Sony Reader Touch Edition PRS-600 Screen Replacement: passo 17, immagine 1 di 1
    • Using the same screwdriver, remove the 1.4 mm screw at the bottom of the device that is usually covered by the bottom and side panel.
    Chiedi a FixBot
    Aggiungi Commento
  18. Sony Reader Touch Edition PRS-600 Screen Replacement: passo 18, immagine 1 di 1
    • Remove the four 1.4 mm screws that are located on the side of the device that are usually covered by the bottom and side panel.
    Chiedi a FixBot
    Aggiungi Commento
  19. Sony Reader Touch Edition PRS-600 Screen Replacement: passo 19, immagine 1 di 1
    • Be sure to lift the thin, orange strip that is attached to the audio/AC/mini USB ports out of the way, before removing the screen.
    Chiedi a FixBot
    Aggiungi Commento
  20. Sony Reader Touch Edition PRS-600 Screen Replacement: passo 20, immagine 1 di 1
    • Lift the end of screen opposite the red edge and pull it out of the casing.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Clemson, Team 1-4, Benson Fall 2014 Membro di Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 Membri
22 guide realizzate
1Commento della guida
where can I get the screen and how much it cost in INR ?
kkrao22 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 37
Tutti i Tempi: 2,909
