Salta al contenuto principale
Sony Reader Touch Edition PRS-600 Power Button Replacement
Cosa ti serve
  1. Sony Reader Touch Edition PRS-600 Power Button Replacement, Back Panel: passo 1, immagine 1 di 1
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
    Chiedi a FixBot
    Aggiungi Commento
  2. Sony Reader Touch Edition PRS-600 Power Button Replacement: passo 2, immagine 1 di 1
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
    Chiedi a FixBot
    Aggiungi Commento
  3. Sony Reader Touch Edition PRS-600 Power Button Replacement: passo 3, immagine 1 di 1
    • This is what the device should look like once the back cover panel has been removed.
    Chiedi a FixBot
    Aggiungi Commento
  4. Sony Reader Touch Edition PRS-600 Power Button Replacement, Battery: passo 4, immagine 1 di 1
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
    Chiedi a FixBot
    Aggiungi Commento
  5. Sony Reader Touch Edition PRS-600 Power Button Replacement: passo 5, immagine 1 di 1
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
    Chiedi a FixBot
    Aggiungi Commento
  6. Sony Reader Touch Edition PRS-600 Power Button Replacement, Power Button: passo 6, immagine 1 di 1
    • Remove the stylus from the device.
    Chiedi a FixBot
    Aggiungi Commento
  7. Sony Reader Touch Edition PRS-600 Power Button Replacement: passo 7, immagine 1 di 3 Sony Reader Touch Edition PRS-600 Power Button Replacement: passo 7, immagine 2 di 3 Sony Reader Touch Edition PRS-600 Power Button Replacement: passo 7, immagine 3 di 3
    • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
    • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
    • Pry apart off the top panel of the device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Clemson, Team 1-4, Benson Fall 2014 Membro di Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 Membri
22 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 41
Tutti i Tempi: 1,021
