Salta al contenuto principale
Sony Pulse Elite Edition Battery Replacement
Cosa ti serve
    1. Sony Pulse Elite Edition Battery Replacement, Identifying Earpiece: passo 1, immagine 1 di 1
      • Locate the left side designation on the headband-earpiece junction.
      • The battery is in the right earpiece.
      • The motherboard is in the left earpiece.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: passo 2, immagine 1 di 2 Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: passo 2, immagine 2 di 2
      • Gently pull around the perimeter of the left ear cushion until it comes off.
      Chiedi a FixBot
      Aggiungi Commento
    3. Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: passo 3, immagine 1 di 2 Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: passo 3, immagine 2 di 2
      • Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
      • Gently pull the outer ear rim off of the headset assembly.
      • Harsh removal may cause permanent damage to the speaker wires.
      Chiedi a FixBot
      Aggiungi Commento
    4. Sony Pulse Elite Edition Battery Replacement, Remove Speaker Housing: passo 4, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      • Using tweezers, gently pry the red and black speaker wires from the attached socket.
      Chiedi a FixBot
      Aggiungi Commento
    1. Sony Pulse Elite Edition Battery Replacement, Remove Battery: passo 5, immagine 1 di 2 Sony Pulse Elite Edition Battery Replacement, Remove Battery: passo 5, immagine 2 di 2
      • Lift up battery and disconnect wires using tweezers.
      • Use a new battery for reconstruction.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 8 persone hanno completato questa guida.
8Commenti sulla guida
Where can I buy the replacement battery for this?
Pretty hard to find...
francisklalumiere - Rispondi Condividi
Replacement batteries can be found by googling "SP70C battery". It is a Lithium battery with 900mAh and a 3.7v output. AliExpress shows them for $11 including shipping.
David McAndrews - Rispondi Condividi
Can I mod and replace the battery with a bigger one with no white connection, just positive and negative? Thanks!
marit - Rispondi Condividi
Thank you so much for this guide. I got a 1000mAh batter from Amazon for 10 dollars. It lasts way longer and was extremely easy to install. Very thankful for this. Thanks!
sharku19z - Rispondi Condividi
i just attempted... the connector to the battery just pulled off. NOTE: Pull up from PCB not out. The connector sets down into it.
Garrett Parmenter - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 9
Ultimi 7 giorni: 54
Ultimi 30 giorni: 190
Tutti i Tempi: 14,234
