Salta al contenuto principale
Sony PlayStation 3D Display Control Buttons Replacement
Cosa ti serve
    1. Sony PlayStation 3D Display Control Buttons Replacement, Rear Case: passo 1, immagine 1 di 2 Sony PlayStation 3D Display Control Buttons Replacement, Rear Case: passo 1, immagine 2 di 2
      • Remove the base by pushing in the button and sliding out the unit.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony PlayStation 3D Display Control Buttons Replacement: passo 2, immagine 1 di 3 Sony PlayStation 3D Display Control Buttons Replacement: passo 2, immagine 2 di 3 Sony PlayStation 3D Display Control Buttons Replacement: passo 2, immagine 3 di 3
      • Remove USB port cover from back plate with a metal spudger.
      • This will prevent the cover from falling under the back plate once it is removed.
      Chiedi a FixBot
      Aggiungi Commento
    3. Sony PlayStation 3D Display Control Buttons Replacement: passo 3, immagine 1 di 2 Sony PlayStation 3D Display Control Buttons Replacement: passo 3, immagine 2 di 2
      • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
      • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
      • These screws have different threads and need to be kept separate.
      Chiedi a FixBot
      Aggiungi Commento
    4. Sony PlayStation 3D Display Control Buttons Replacement: passo 4, immagine 1 di 3 Sony PlayStation 3D Display Control Buttons Replacement: passo 4, immagine 2 di 3 Sony PlayStation 3D Display Control Buttons Replacement: passo 4, immagine 3 di 3
      • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
      • Be gentle to avoid breaking the plastic clips which hold the plate.
      • Once separated the plate easily lifts off.
      Chiedi a FixBot
      Aggiungi Commento
    1. Sony PlayStation 3D Display Control Buttons Replacement, Control Buttons: passo 5, immagine 1 di 1
      • With the Phillips #01 screwdriver, remove the two 5 mm length x 7 mm head screws from the top and bottom of the control button bar.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony PlayStation 3D Display Control Buttons Replacement: passo 6, immagine 1 di 2 Sony PlayStation 3D Display Control Buttons Replacement: passo 6, immagine 2 di 2
      • Detach the control button bar by depressing the small white tab that connects the bar to its wires.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team 12-16, Maness Fall 2015 Membro di Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 10
Ultimi 30 giorni: 27
Tutti i Tempi: 999
