Salta al contenuto principale
Sony ICF-C1T Screen Replacement
Cosa ti serve
    1. Sony ICF-C1T Screen Replacement, Screen: passo 1, immagine 1 di 1
      • Make sure the clock is unplugged from the wall and the replacement battery has been taken out of the clock to prevent harm to you and to the clock.
      • Use a Phillips 00 head screwdriver to remove the four 14 mm screws from the bottom of the clock.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony ICF-C1T Screen Replacement: passo 2, immagine 1 di 1
      • Insert the plastic opening tool to pry apart the top and sides of the device gently.
      Chiedi a FixBot
      Aggiungi Commento
    3. Sony ICF-C1T Screen Replacement: passo 3, immagine 1 di 2 Sony ICF-C1T Screen Replacement: passo 3, immagine 2 di 2
      • Carefully pull the top of clock off as the clock display is located directly behind the face plate and is still connected by multiple wires.
      • Pull the top of the device away from the rest of the clock to expose the inside.
      Chiedi a FixBot
      Aggiungi Commento
    4. Sony ICF-C1T Screen Replacement: passo 4, immagine 1 di 2 Sony ICF-C1T Screen Replacement: passo 4, immagine 2 di 2
      • Do not use too much pressure on the plastic to not break it.
      • Add pressure to the inside of the screen so that a small area is loosened enough to be able to use an opening tool.
      • Use the plastic opening tool to separate the screen from the device.
      Chiedi a FixBot
      Aggiungi Commento
    5. Sony ICF-C1T Screen Replacement: passo 5, immagine 1 di 2 Sony ICF-C1T Screen Replacement: passo 5, immagine 2 di 2
      • Apply a tinted spray to dim the brightness once the tinted sheet is out of the way.
      • Another way to solve the brightness problem is to apply a tinted color sheet protector.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 14
Ultimi 30 giorni: 48
Tutti i Tempi: 5,667
