Salta al contenuto principale
Sony FDL-220R Watchman Button Replacement
Cosa ti serve
    1. Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: passo 1, immagine 1 di 2 Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: passo 1, immagine 2 di 2
      • Press down on the textured area and push towards the bottom of the device.
      • Gently remove the battery cover.
      • Remove the three AA batteries.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony FDL-220R Watchman Button Replacement, Remove screws: passo 2, immagine 1 di 2 Sony FDL-220R Watchman Button Replacement, Remove screws: passo 2, immagine 2 di 2
      • Locate the five 5x11mm screws surrounding the battery compartment.
      • Remove screws with a Philips #00 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    3. Sony FDL-220R Watchman Button Replacement, Remove back casing: passo 3, immagine 1 di 2 Sony FDL-220R Watchman Button Replacement, Remove back casing: passo 3, immagine 2 di 2
      • Grasp the entire back half of the Watchman's casing.
      • Snap off the casing from the bottom of the device.
      • Gently pull off entire back casing.
      Chiedi a FixBot
      Aggiungi Commento
    4. Sony FDL-220R Watchman Button Replacement, Remove circuit board: passo 4, immagine 1 di 3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: passo 4, immagine 2 di 3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: passo 4, immagine 3 di 3
      • Carefully grasp the entire circuit board.
      • Pull the circuit board off of the device's plastic casing.
      Chiedi a FixBot
      Aggiungi Commento
    5. Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: passo 5, immagine 1 di 2 Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: passo 5, immagine 2 di 2
      • Locate the thee plastic buttons/switches on the sides of the plastic grey casing.
      • Buttons/switches should be simply resting in their slots on the device.
      • Remove all three buttons/switches.
      • If the buttons/switches are dirty, clean them in warm water and dry thoroughly.
      • If one of the buttons/switches is broken, simply replace it with a new one.
      • When replacing, make sure that the slot on the switches faces up.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Sam Putnam
Membro da: 10/22/14
484 Reputazione
4 guide realizzate
Baylor, Team 4-5, Williams Fall 2014 Membro di Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 6
Ultimi 30 giorni: 27
Tutti i Tempi: 568
