Salta al contenuto principale
Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement
Cosa ti serve
    1. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Battery: passo 1, immagine 1 di 2 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Battery: passo 1, immagine 2 di 2
      • Locate the battery door at the bottom of the camera.
      • Press down on the door and slide it back. The door will pop open.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: passo 2, immagine 1 di 1
      • Remove the battery from the door that you opened in the previous step.
      Chiedi a FixBot
      Aggiungi Commento
    1. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, immagine 1 di 3 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, immagine 2 di 3 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, immagine 3 di 3
      • There are two screws on the left and right sides of the camera, and two screws on the bottom.
      • Use a PH00 screwdriver and remove the six 2.9mm screws.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: passo 4, immagine 2 di 2
      • Use hands to gently pry the front casing away from the camera.
      Chiedi a FixBot
      Aggiungi Commento
    1. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, CCD Sensor Module: passo 5, immagine 1 di 2 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, CCD Sensor Module: passo 5, immagine 2 di 2
      • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
      • The second picture shows what these tabs look like in their open positions.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: passo 6, immagine 1 di 1
      • Grasp the CCD Sensor Module and remove it.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
iDeleted
Membro da: 07/07/10
2.101 Reputazione
39 guide realizzate
1Commento della guida
where I can buy it?
Francesco Cortese - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 29
Ultimi 30 giorni: 152
Tutti i Tempi: 15,223
