Introduzione
This guide will help you to replace the lens assembly on the Sony Cyber Shot DSC-W170.
If the camera lens is cracked or otherwise damaged, the solution is to replace the camera lens.
Be careful when removing shattered glass displays, be sure to remove power/disconnect batteries ,and take a look at the ESD-safe tools website before performing this task!
A necessary skill is to be able to use a soldering iron.
Take a look at our troubleshooting page if you need help to remove the battery.
On the Sony website you can find replacement parts for the camera.
Cosa ti serve
Remove the first side panel to the left of the LCD.
Remove the 4 mm screw from the other side panel to the right of the LCD with a Phillips #000 screwdriver.
Desolder the wires connecting the top panel circuit board from the lens with the soldering iron.
