Salta al contenuto principale
Sony Clie PEG-NR70 Audio Module Replacement
Cosa ti serve
    1. Sony Clie PEG-NR70 Audio Module Replacement, The Case: passo 1, immagine 1 di 1
      • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
      • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony Clie PEG-NR70 Audio Module Replacement: passo 2, immagine 1 di 1
      • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    3. Sony Clie PEG-NR70 Audio Module Replacement: passo 3, immagine 1 di 2 Sony Clie PEG-NR70 Audio Module Replacement: passo 3, immagine 2 di 2
      • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
      • Remove the back panel by lifting it away with your hands.
      Chiedi a FixBot
      Aggiungi Commento
    1. Sony Clie PEG-NR70 Audio Module Replacement, Audio Module: passo 4, immagine 1 di 1
      • Unscrew the 2.5mm screw on the top portion of the audio module with a Phillips #00 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony Clie PEG-NR70 Audio Module Replacement: passo 5, immagine 1 di 1
      • Remove the tape that is holding the module down.
      Chiedi a FixBot
      Aggiungi Commento
    3. Sony Clie PEG-NR70 Audio Module Replacement: passo 6, immagine 1 di 1
      • Lift up the orange ribbon cable and unscrew the two 2.5mm screws located at the corners of the audio module with a Phillips #00 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    4. Sony Clie PEG-NR70 Audio Module Replacement: passo 7, immagine 1 di 1
      • Unplug the audio module from the motherboard by disconnecting the wires by lifting the orange wire up.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team 14-11, Maness Spring 2013 Membro di Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Membri
47 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 13
Ultimi 30 giorni: 34
Tutti i Tempi: 994
