Salta al contenuto principale
Sony CCD-TR81 Microphone Casing Replacement
Cosa ti serve
  1. Sony CCD-TR81 Microphone Casing Replacement, Disassembling Sony CCD-TR81 Battery: passo 1, immagine 1 di 1
    • Lift viewfinder to access battery pack.
    Chiedi a FixBot
    Aggiungi Commento
  2. Sony CCD-TR81 Microphone Casing Replacement: passo 2, immagine 1 di 2 Sony CCD-TR81 Microphone Casing Replacement: passo 2, immagine 2 di 2
    • Press the battery release button.
    • While pushing the battery button, slide the battery to the left.
    Chiedi a FixBot
    Aggiungi Commento
  3. Sony CCD-TR81 Microphone Casing Replacement: passo 3, immagine 1 di 1
    • Pull the battery pack out of the video camera.
    Chiedi a FixBot
    Aggiungi Commento
  4. Sony CCD-TR81 Microphone Casing Replacement, Outer Case: passo 4, immagine 1 di 3 Sony CCD-TR81 Microphone Casing Replacement, Outer Case: passo 4, immagine 2 di 3 Sony CCD-TR81 Microphone Casing Replacement, Outer Case: passo 4, immagine 3 di 3
    • Open the cassette cover.
    • Unscrew 14 screws located on the outer casing. Three are located on the top face 2x6.8mm and 1X4.54mm, three on the left face 1x4.54mm,1x5.3mm and seven on the bottom face 5x4.54mm and 2x6.77mm.
    Chiedi a FixBot
    Aggiungi Commento
  5. Sony CCD-TR81 Microphone Casing Replacement: passo 5, immagine 1 di 2 Sony CCD-TR81 Microphone Casing Replacement: passo 5, immagine 2 di 2
    • Remove five screws from the right side, from bottom to top, 3x4.54mm 2x5.70mm.
    • Remove the single 4.5 mm screw from the backside.
    Chiedi a FixBot
    Aggiungi Commento
  6. Sony CCD-TR81 Microphone Casing Replacement: passo 6, immagine 1 di 1
    • Pull off the plastic tape cover by lifting it up and out of the camera base.
    Chiedi a FixBot
    Aggiungi Commento
  7. Sony CCD-TR81 Microphone Casing Replacement: passo 7, immagine 1 di 1
    • Disconnect the mic assembly by pulling it away from the camera base.
    • Do not pull too hard as the wires are still connected.
    Chiedi a FixBot
    Aggiungi Commento
  8. Sony CCD-TR81 Microphone Casing Replacement: passo 8, immagine 1 di 1
    • Pull the bottom part of the case away from the camera.
    Chiedi a FixBot
    Aggiungi Commento
  9. Sony CCD-TR81 Microphone Casing Replacement: passo 9, immagine 1 di 1
    • Remove the three 4.5 mm screws from the right face of the video camera.
    Chiedi a FixBot
    Aggiungi Commento
  10. Sony CCD-TR81 Microphone Casing Replacement: passo 10, immagine 1 di 1
    • Remove the single 3.6 mm screw at the front of the video camera on the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  11. Sony CCD-TR81 Microphone Casing Replacement: passo 11, immagine 1 di 1
    • Pull the audio/video inputs underneath the microphone assembly. The inputs should still be connected to the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  12. Sony CCD-TR81 Microphone Casing Replacement: passo 12, immagine 1 di 1
    • Remove two remaining 3.6 mm case screws from the front of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  13. Sony CCD-TR81 Microphone Casing Replacement: passo 13, immagine 1 di 2 Sony CCD-TR81 Microphone Casing Replacement: passo 13, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Using metal tweezers, pull out the plastic connector box on the front side.
    • Again use metal tweezers to pull out the connection box on the bottom of the camera. The right side of the case can now be removed by pulling it to the right.
    Chiedi a FixBot
    Aggiungi Commento
  14. Sony CCD-TR81 Microphone Casing Replacement, Microphone Casing: passo 14, immagine 1 di 1
    • Unscrew the blue screw behind microphone and remove it from the video camera 1x3.6mm.
    Chiedi a FixBot
    Aggiungi Commento
  15. Sony CCD-TR81 Microphone Casing Replacement: passo 15, immagine 1 di 1
    • Pull the circuit board up and away from the microphone case.
    Chiedi a FixBot
    Aggiungi Commento
  16. Sony CCD-TR81 Microphone Casing Replacement: passo 16, immagine 1 di 1
    • Pull up metal brackets with plastic removal tool.
    Chiedi a FixBot
    Aggiungi Commento
  17. Sony CCD-TR81 Microphone Casing Replacement: passo 17, immagine 1 di 1
    • With the plastic removal tool, pry up the microphone housing units. This will allow access to the camcorder microphone.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 11-25, Maness Winter 2011 Membro di Cal Poly, Team 11-25, Maness Winter 2011
CPSU-MANESS-W11S11G25
4 Membri
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 34
Tutti i Tempi: 1,607
