Salta al contenuto principale
Sony Alpha NEX-6 Control Wheel Replacement
Cosa ti serve
    1. Sony Alpha NEX-6 Control Wheel Replacement, Battery: passo 1, immagine 1 di 1
      • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
      • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony Alpha NEX-6 Control Wheel Replacement: passo 2, immagine 1 di 1
      • Flip the camera upside-down and carefully place it on a flat surface.
      • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
      • Push the latch to the right to unlock the battery compartment. The door should flip upward.
      Chiedi a FixBot
      Aggiungi Commento
    3. Sony Alpha NEX-6 Control Wheel Replacement: passo 3, immagine 1 di 1
      • With the compartment open, locate a blue tab shown with spudger
      • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
      Chiedi a FixBot
      Aggiungi Commento
    1. Sony Alpha NEX-6 Control Wheel Replacement, Battery compartment screws: passo 4, immagine 1 di 1
      • Remove the two 3.5mm Phillips #00 screws that hold the back case - located inside the battery compartment.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony Alpha NEX-6 Control Wheel Replacement, Bottom screws: passo 5, immagine 1 di 1
      • Remove the two 3.5mm Phillips #00 screws that hold the back case - located on the bottom of the camera.
      Chiedi a FixBot
      Aggiungi Commento
    3. Sony Alpha NEX-6 Control Wheel Replacement, Side screws: passo 6, immagine 1 di 1
      • Remove the 3.5 mm Phillips #00 screw on the side of camera - located between the charging and HDMI ports.
      • Remove the 4.0 mm Phillips #00 screw on the side of the camera - located next to the WiFi sign.
      Chiedi a FixBot
      Aggiungi Commento
    4. Sony Alpha NEX-6 Control Wheel Replacement, Dis-attaching procedure: passo 7, immagine 1 di 2 Sony Alpha NEX-6 Control Wheel Replacement, Dis-attaching procedure: passo 7, immagine 2 di 2
      • Starting with the battery compartment gently begin to separate the back case front the camera.
      • Using a plastic opening tool, separate the bottom of the back case from the camera. Then proceed by separating the sides.
      • Gently lift the back case away from the camera an slide it down to completely remove the back case.
      Chiedi a FixBot
      Aggiungi Commento
    1. Sony Alpha NEX-6 Control Wheel Replacement, Control Wheel: passo 8, immagine 1 di 2 Sony Alpha NEX-6 Control Wheel Replacement, Control Wheel: passo 8, immagine 2 di 2
      • Pry out the ribbon cable by carefully pushing on its side tabs with a spudger.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony Alpha NEX-6 Control Wheel Replacement, Control wheel romoval: passo 9, immagine 1 di 2 Sony Alpha NEX-6 Control Wheel Replacement, Control wheel romoval: passo 9, immagine 2 di 2
      Strumento utilizzato in questo passaggio:
      • Using a spudger, lift the metal locking tab located at the top right corner of control wheel assembly.
      • Using tweezers, carefully slide the assembly up to release it.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Clayton Dale
Membro da: 01/20/15
1.067 Reputazione
7 guide realizzate
USF Tampa, Team 11-2, Blackwell Winter 2015 Membro di USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 15
Ultimi 30 giorni: 52
Tutti i Tempi: 6,034
