Salta al contenuto principale
Sony Action Cam HDR-AS15 Memory Card Replacement
    1. Sony Action Cam HDR-AS15 Memory Card Replacement, Getting to the Memory Card: passo 1, immagine 1 di 1
      • To access the memory card, push left on the rear of the Action Cam. The rear panel should easily slide to the side.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony Action Cam HDR-AS15 Memory Card Replacement, Removing the card: passo 2, immagine 1 di 1
      • After sliding the rear panel to the side, open the door outward to reveal the memory card slot and battery tray.
      • Push in on the back of the memory card with the tip of your finger until you feel a click.
      • Pinch the rear of the memory card that is protruding from the slot and pull on it until the memory card is removed.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
USF Tampa, Team 1-2, Sullivan Winter 2015 Membro di USF Tampa, Team 1-2, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G2
4 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 37
Tutti i Tempi: 1,022
