Salta al contenuto principale
Sony AZ1VR LCD Side Display Replacement
Cosa ti serve
    1. Sony AZ1VR LCD Side Display Replacement, LCD Side Display: passo 1, immagine 1 di 3 Sony AZ1VR LCD Side Display Replacement, LCD Side Display: passo 1, immagine 2 di 3 Sony AZ1VR LCD Side Display Replacement, LCD Side Display: passo 1, immagine 3 di 3
      • Remove the two screws on the bottom of the camera.
      • Remove the screw inside the battery door.
      • Once these are removed, slide the door out, and the small piece of plastic with the door.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony AZ1VR LCD Side Display Replacement: passo 2, immagine 1 di 3 Sony AZ1VR LCD Side Display Replacement: passo 2, immagine 2 di 3 Sony AZ1VR LCD Side Display Replacement: passo 2, immagine 3 di 3
      • Grab the lens and pull the body out of the plastic, this will reveal the insides of the device.
      • You'll see a screw on the top of the device, towards the front, remove this screw.
      • Pull the tabs on the bottom and top of the lens, and pull outward, this will remove the lens housing from the body.
      Chiedi a FixBot
      Aggiungi Commento
    3. Sony AZ1VR LCD Side Display Replacement: passo 3, immagine 1 di 3 Sony AZ1VR LCD Side Display Replacement: passo 3, immagine 2 di 3 Sony AZ1VR LCD Side Display Replacement: passo 3, immagine 3 di 3
      • Remove the screws connected to the silver metal plate.
      • Remove the plate by pulling the back up and pushing it towards the front.
      • Remove the screw directly above the LCD display.
      • Pull the plastic up gently, it will be connected by cables on the bottom.
      • Disconnect the cable going to the LCD display.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 17
Tutti i Tempi: 364
