Salta al contenuto principale
Sol Republic Deck Play/Pause Button Replacement
Cosa ti serve
    1. Sol Republic Deck Play/Pause Button Replacement, Play/Pause Button: passo 1, immagine 1 di 3 Sol Republic Deck Play/Pause Button Replacement, Play/Pause Button: passo 1, immagine 2 di 3 Sol Republic Deck Play/Pause Button Replacement, Play/Pause Button: passo 1, immagine 3 di 3
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      • Pry the front face plate from the bottom half of the speaker by inserting the spudger edge into the the middle groove.
      • Insert another spudger into the middle groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sol Republic Deck Play/Pause Button Replacement: passo 2, immagine 1 di 1
      • On the front face of the device, locate the green plastic Motorola (M) button that controls the playing and pausing of music.
      Chiedi a FixBot
      Aggiungi Commento
    3. Sol Republic Deck Play/Pause Button Replacement: passo 3, immagine 1 di 1
      • Using your finger, push the M button towards the inside of the device.
      Chiedi a FixBot
      Aggiungi Commento
    4. Sol Republic Deck Play/Pause Button Replacement: passo 4, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      • Using the tweezers, grab the button as it comes through and pull it carefully off of the pegs.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 25
Tutti i Tempi: 1,162
