Salta al contenuto principale
Sol Republic Deck LED Lights Replacement
Cosa ti serve
    1. Sol Republic Deck LED Lights Replacement, LED Lights: passo 1, immagine 1 di 2 Sol Republic Deck LED Lights Replacement, LED Lights: passo 1, immagine 2 di 2
      Strumento utilizzato in questo passaggio:
      Spudger
      $3.99
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      • Insert the tip of a plastic opening tool or Spudger into the the middle groove along the edge of the device.
      • Insert another opening tool into the groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sol Republic Deck LED Lights Replacement: passo 2, immagine 1 di 2 Sol Republic Deck LED Lights Replacement: passo 2, immagine 2 di 2
      Phillips #00 Screwdriver
      $5.49
      • Using a Phillips #00 Screwdriver, unscrew the two three-tenth cm screws and remove them.
      • Once the screws have been removed, lift the SOL plate revealing the LED Light strip.
      Chiedi a FixBot
      Aggiungi Commento
    3. Sol Republic Deck LED Lights Replacement: passo 3, immagine 1 di 1
      $5.49
      Chiedi a FixBot
      Aggiungi Commento
    4. Sol Republic Deck LED Lights Replacement: passo 4, immagine 1 di 1
      $5.49
      Chiedi a FixBot
      Aggiungi Commento
    5. Sol Republic Deck LED Lights Replacement: passo 5, immagine 1 di 1
      • Use fingers to gently lift tab to help remove ZIF connector.
      • Use tweezers and to gently lift ZIF (Zero Insertion Force) connector.
      Chiedi a FixBot
      Aggiungi Commento
    6. Sol Republic Deck LED Lights Replacement: passo 6, immagine 1 di 1
      • Once unscrewed, the LED light requiring repair can be accessed by lifting up the entire LED light strip with tweezers.
      Chiedi a FixBot
      Aggiungi Commento
    7. Sol Republic Deck LED Lights Replacement: passo 7, immagine 1 di 1
      • Lift the LED light plate attached to the motherboard off.
      • If you pull the LED light plate too hard, then the motherboard will snap in half.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 4
Ultimi 30 giorni: 22
Tutti i Tempi: 2,450
