Salta al contenuto principale
Snapfon ez One SIM Card Replacement
Cosa ti serve
  1. Snapfon ez One SIM Card Replacement, Remove the battery cover: passo 1, immagine 1 di 1
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
    Chiedi a FixBot
    Aggiungi Commento
  2. Snapfon ez One SIM Card Replacement, Remove the battery: passo 2, immagine 1 di 1
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
    Chiedi a FixBot
    Aggiungi Commento
  3. Snapfon ez One SIM Card Replacement, SIM Card: passo 3, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Use the tweezers,if needed, to grasp the SIM card for removal. Apply a slight pulling tension and remove it from under the tabs as shown.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reinsert the SIM card or a new SIM card, position the card in the same orientation seen in the figure with the brass connections facing the phone while using thumb to apply a slight force until the card rest inside of the recessed holder. Make sure the brass contacts of the card and phone connect. Then follow the steps in reverse order to reassemble phone.
Clemson, Team 6-5, Benson Spring 2014 Membro di Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
3 Membri
24 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 9
Ultimi 30 giorni: 47
Tutti i Tempi: 1,536
