Salta al contenuto principale
Smontaggio DJI Mini 4 Pro
Cosa ti serve
Istruzioni Video
Conclusione
Per rassembrare il dispositivo, seguire le istruzioni video.
Altre 11 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
I1Nic ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Arty
Membro da: 10/27/19
34.208 Reputazione
110 guide realizzate
5Commenti sulla guida
Fantastic! My issue is losing connection even at 10 feet. I'm guessing the antenna is loose? Is there a guide to check the connections for the antenna?
Kevin - Rispondi Condividi
@kevin68196 test same remote on another drone first. Or try with another remote on your drone.
adrianTNT - Rispondi Condividi
@adriantnt I disassembled the drone and re attached the four arm connections. It worked great for 15 mins while flying and then lost signal again. Need to take it apart again.
Kevin Kaiser - Rispondi Condividi
@kevinkaise18799 I think some have hot glue on the antenna connectors to keep them in place, maybe that helps (if they popped out). Are the propellers OK? Maybe it causes excessive vibration. Just some ideas :)
@adriantnt I used hot glue but maybe it vibrated loose again. I should probably replace the propellers. They are original and are a little worn. Thanks!
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 22
Ultimi 7 giorni: 134
Ultimi 30 giorni: 536
Tutti i Tempi: 10,962
