Salta al contenuto principale
Smart Parts Ion Bolt Replacement
Cosa ti serve
    1. Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: passo 1, immagine 1 di 3 Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: passo 1, immagine 2 di 3 Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: passo 1, immagine 3 di 3
      • Remove the air tank by rotating it counterclockwise.
      • Do not pull the trigger or jostle the gun, there will still be pressurized air inside the gun that could be expelled and cause bodily harm if injected into eyes and/or skin.
      • The pressure gauge will indicate the leftover air in the gun.
      Chiedi a FixBot
      Aggiungi Commento
    2. Smart Parts Ion Bolt Replacement: passo 2, immagine 1 di 2 Smart Parts Ion Bolt Replacement: passo 2, immagine 2 di 2
      • Remove the hopper by pulling it out of the feed tube, located on the top of the body. The hopper should easily come off when pulled straight up.
      Chiedi a FixBot
      Aggiungi Commento
    1. Smart Parts Ion Bolt Replacement, Smart Parts Ion De-Gassing: passo 3, immagine 1 di 1
      • Turn the gun on by pressing the power button until the red light blinks.
      • Turn vision mode off by pressing the power button again.
      • Red light should be flashing in a double blink sequence.
      Chiedi a FixBot
      Aggiungi Commento
    2. Smart Parts Ion Bolt Replacement: passo 4, immagine 1 di 1
      • Pull the trigger to release the air in the gun.
      • Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels, causing embolisms. To avoid this, make sure to point the gun in a safe direction when pulling the trigger because air will be released from the gun.
      Chiedi a FixBot
      Aggiungi Commento
    1. Smart Parts Ion Bolt Replacement, Grip: passo 5, immagine 1 di 1
      • Remove the four 8mm screws on each side of the gun's grip using a Phillips #2 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Smart Parts Ion Bolt Replacement: passo 6, immagine 1 di 1
      • Remove the grip by sliding it towards the front of the gun.
      Chiedi a FixBot
      Aggiungi Commento
    1. Smart Parts Ion Bolt Replacement, Battery: passo 7, immagine 1 di 2 Smart Parts Ion Bolt Replacement, Battery: passo 7, immagine 2 di 2
      • Remove the 9V battery by unsnapping it.
      Chiedi a FixBot
      Aggiungi Commento
    1. Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: passo 8, immagine 1 di 3 Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: passo 8, immagine 2 di 3 Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: passo 8, immagine 3 di 3
      • Remove the front and rear 1" screws on the gun's grip frame using a 3/32" Allen Wrench.
      Chiedi a FixBot
      Aggiungi Commento
    2. Smart Parts Ion Bolt Replacement: passo 9, immagine 1 di 2 Smart Parts Ion Bolt Replacement: passo 9, immagine 2 di 2
      • Remove the 12 mm screw on the top of the grip frame using a 3/32" Allen wrench.
      Chiedi a FixBot
      Aggiungi Commento
    3. Smart Parts Ion Bolt Replacement: passo 10, immagine 1 di 1
      • Separate the gun's body from the frame by gently pulling them in opposite directions.
      Chiedi a FixBot
      Aggiungi Commento
    4. Smart Parts Ion Bolt Replacement: passo 11, immagine 1 di 1
      • Remove the 1-1/4" screw that's attached to the blue tube above the front grip using a 3/32" Allen Wrench.
      Chiedi a FixBot
      Aggiungi Commento
    1. Smart Parts Ion Bolt Replacement, Removing the Solenoid from the Body: passo 12, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      • Gently use tweezers to detach the white vision wire harness, located directly under the feed tube.
      • Another small tool or your fingers will work for this.
      Chiedi a FixBot
      Aggiungi Commento
    2. Smart Parts Ion Bolt Replacement: passo 13, immagine 1 di 1
      • Remove the two 1-1/4" screws on either side of the circuit board using a 3/32" allen wrench.
      Chiedi a FixBot
      Aggiungi Commento
    3. Smart Parts Ion Bolt Replacement: passo 14, immagine 1 di 1
      • Separate the solenoid from the gun's body by gently pulling it upwards.
      Chiedi a FixBot
      Aggiungi Commento
    4. Smart Parts Ion Bolt Replacement: passo 15, immagine 1 di 1
      • Slide the metal body out of the plastic shell by holding one in each hand and gently pulling apart.
      Chiedi a FixBot
      Aggiungi Commento
    1. Smart Parts Ion Bolt Replacement, Bolt: passo 16, immagine 1 di 2 Smart Parts Ion Bolt Replacement, Bolt: passo 16, immagine 2 di 2
      • Separate the front body breach from the fire chamber by rotating the breach counterclockwise.
      Chiedi a FixBot
      Aggiungi Commento
    2. Smart Parts Ion Bolt Replacement: passo 17, immagine 1 di 1
      • Remove the bolt from the front body breach by gently pulling on the bolt.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 8-42, Amido Winter 2015 Membro di Cal Poly, Team 8-42, Amido Winter 2015
CPSU-AMIDO-W15S8G42
4 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 33
Tutti i Tempi: 3,270
