Salta al contenuto principale
Skytex SP728 Screen Replacement
Cosa ti serve
  1. Skytex SP728 Screen Replacement, Case: passo 1, immagine 1 di 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
    Chiedi a FixBot
    Aggiungi Commento
  2. Skytex SP728 Screen Replacement: passo 2, immagine 1 di 1
    • Using a small phillips screwdriver, unscrew both end screws
    Chiedi a FixBot
    Aggiungi Commento
  3. Skytex SP728 Screen Replacement: passo 3, immagine 1 di 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
    Chiedi a FixBot
    Aggiungi Commento
  4. Skytex SP728 Screen Replacement: passo 4, immagine 1 di 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
    Chiedi a FixBot
    Aggiungi Commento
  5. Skytex SP728 Screen Replacement, Screen: passo 5, immagine 1 di 3 Skytex SP728 Screen Replacement, Screen: passo 5, immagine 2 di 3 Skytex SP728 Screen Replacement, Screen: passo 5, immagine 3 di 3
    • Follow the Case Replacement to separate the tablet from its backing
    • Using a small Phillips screw driver, unscrew all screws connecting circuit board to device
    • Remove all tape connecting battery and circuit board to front case
    • Detach all connector strips from the circuit board
    Chiedi a FixBot
    Aggiungi Commento
  6. Skytex SP728 Screen Replacement: passo 6, immagine 1 di 2 Skytex SP728 Screen Replacement: passo 6, immagine 2 di 2
    • Using the plastic opening tool, begin separating the front screen from the display
    Chiedi a FixBot
    Aggiungi Commento
  7. Skytex SP728 Screen Replacement: passo 7, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Once screen has been separated, use tweezers to remove front camera
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device with a new screen, follow these instructions in reverse order.
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 5-1, Brown Winter 2015 Membro di USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Membri
11 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 29
Tutti i Tempi: 441
