Salta al contenuto principale
Skullcandy Crusher Wireless Earpiece Speaker Replacement
Cosa ti serve
  1. Skullcandy Crusher Wireless Earpiece Speaker Replacement, Ear Cushion: passo 1, immagine 1 di 2 Skullcandy Crusher Wireless Earpiece Speaker Replacement, Ear Cushion: passo 1, immagine 2 di 2
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 2, immagine 1 di 2 Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 2, immagine 2 di 2
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 3, immagine 1 di 1
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Earpiece Speaker Replacement, USB Connector: passo 4, immagine 1 di 2 Skullcandy Crusher Wireless Earpiece Speaker Replacement, USB Connector: passo 4, immagine 2 di 2
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion.
  5. Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 5, immagine 1 di 3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 5, immagine 2 di 3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 5, immagine 3 di 3
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 6, immagine 1 di 2 Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 6, immagine 2 di 2
    • Separate the headphone speaker assembly from headphone speaker frame.
  7. Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 7, immagine 1 di 1
    • Inspect the USB port and ensure that it is connected correctly. If necessary, desolder the USB port and replace it with the new port.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
  8. Skullcandy Crusher Wireless Earpiece Speaker Replacement, Earpiece Speaker: passo 8, immagine 1 di 3 Skullcandy Crusher Wireless Earpiece Speaker Replacement, Earpiece Speaker: passo 8, immagine 2 di 3 Skullcandy Crusher Wireless Earpiece Speaker Replacement, Earpiece Speaker: passo 8, immagine 3 di 3
    • Remove four 4 mm Phillips #1 screws that connect the motherboard with the plastic frame.
  9. Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 9, immagine 1 di 3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 9, immagine 2 di 3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 9, immagine 3 di 3
    • Remove three 4 mm Phillips #1 screws that connect the bass speaker to the plastic frame.
  10. Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 10, immagine 1 di 3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 10, immagine 2 di 3 Skullcandy Crusher Wireless Earpiece Speaker Replacement: passo 10, immagine 3 di 3
    • Move the motherboard away from the plastic frame.
    • Desolder two cables to replace the speaker and bass component.
Conclusione
Val
Membro da: 03/31/22
1.125 Reputazione
6 Guide realizzate
Un commento
Como puedo conseguir los altavoces bajos?
Rodery Josè Garcia Hidalgo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 109
Tutti i Tempi: 2,572
