Salta al contenuto principale
Skullcandy Crusher Wireless Bluetooth Antenna Replacement
Cosa ti serve
  1. Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Ear Cushion: passo 1, immagine 1 di 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Ear Cushion: passo 1, immagine 2 di 2
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 2, immagine 1 di 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 2, immagine 2 di 2
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 3, immagine 1 di 1
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Bluetooth Antenna: passo 4, immagine 1 di 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Bluetooth Antenna: passo 4, immagine 2 di 2
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
  5. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 5, immagine 1 di 3 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 5, immagine 2 di 3 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 5, immagine 3 di 3
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker assembly away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 6, immagine 1 di 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 6, immagine 2 di 2
    • Separate headphone speaker assembly from headphone speaker frame.
  7. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: passo 7, immagine 1 di 1
    • The Bluetooth antenna module chip is located on the right top corner of the motherboard.
    • If necessary, the chip module can be desoldered and replaced with a new one. Or, the motherboard can be replaced.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
Conclusione
Val
Membro da: 03/31/22
1.125 Reputazione
6 Guide realizzate
Un commento
Where can one purchase a replacement chip?
Josh - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 41
Tutti i Tempi: 1,047
