Salta al contenuto principale
Skullcandy Crusher Wireless Battery Replacement
Cosa ti serve
  1. Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: passo 1, immagine 1 di 2 Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: passo 1, immagine 2 di 2
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Battery Replacement: passo 2, immagine 1 di 2 Skullcandy Crusher Wireless Battery Replacement: passo 2, immagine 2 di 2
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Battery Replacement: passo 3, immagine 1 di 1
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Battery Replacement, Battery: passo 4, immagine 1 di 2 Skullcandy Crusher Wireless Battery Replacement, Battery: passo 4, immagine 2 di 2
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
    • You have to work on the right-side earphone.
  5. Skullcandy Crusher Wireless Battery Replacement: passo 5, immagine 1 di 3 Skullcandy Crusher Wireless Battery Replacement: passo 5, immagine 2 di 3 Skullcandy Crusher Wireless Battery Replacement: passo 5, immagine 3 di 3
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker part away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Battery Replacement: passo 6, immagine 1 di 2 Skullcandy Crusher Wireless Battery Replacement: passo 6, immagine 2 di 2
    • Separate the headphone speaker assembly from the headphone speaker frame.
  7. Skullcandy Crusher Wireless Battery Replacement: passo 7, immagine 1 di 3 Skullcandy Crusher Wireless Battery Replacement: passo 7, immagine 2 di 3 Skullcandy Crusher Wireless Battery Replacement: passo 7, immagine 3 di 3
    • Remove the battery from the headphone housing.
    • Use a soldering iron to desolder the black, red, and yellow cables from the board and disconnect the battery.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
Conclusione
Altre 4 persone hanno completato questa guida.
Val
Membro da: 03/31/22
1.125 Reputazione
6 Guide realizzate
4 Commenti
Hi, Can you specify this replacement batterys name and model number?
kituserkituserkituser kit - Replica
1050mAh, 3,7V 3,885Wh
Mika Björn Wilhelmsen -
Which battery should i buy for my skull candy hes evo??
Lakshit Meena - Replica
donde puedo conseguir la bateria de los skullcandy crusher?
y cual bateria lleva?
pedro landeros - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 17
Ultimi 7 Giorni: 77
Ultimi 30 Giorni: 293
Tutti i Tempi: 9,660
