Salta al contenuto principale
Shure SM58 Grille Replacement
    1. Shure SM58 Grille Replacement, Grille: passo 1, immagine 1 di 1
      • Hold the microphone just below the grille with one hand while using your other hand to rotate the grille clockwise to remove.
      Chiedi a FixBot
      Aggiungi Commento
    2. Shure SM58 Grille Replacement: passo 2, immagine 1 di 2 Shure SM58 Grille Replacement: passo 2, immagine 2 di 2
      • Completely unscrew the grille and slide it off of the top of the microphone. The unprotected microphone is delicate, so place it somewhere safe while you follow the next steps.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Follow the steps in reverse to install the new grille on the microphone.
Altre 5 persone hanno completato questa guida.
nat coll
Membro da: 09/27/12
859 Reputazione
14 guide realizzate
Cal Poly, Team 7-53, Forte Fall 2012 Membro di Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Membri
61 guide realizzate
2Commenti sulla guida
Can you change the grilles of sm58 and sm86?
Jack - Rispondi Condividi
Hello, I have two SM58 (wired), No matter how I tried to remove the grill from one of them, It just would not budge. With the other one, The grill comes off, but the base refuses to unscrew. Can you tell me how to solve this issue? Thanks in advance.
junia joseph - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 15
Ultimi 30 giorni: 79
Tutti i Tempi: 11,485
