Salta al contenuto principale
Shure SM58 Capsule Installation Replacement
Cosa ti serve
  1. Shure SM58 Capsule Installation Replacement, Collar: passo 1, immagine 1 di 3 Shure SM58 Capsule Installation Replacement, Collar: passo 1, immagine 2 di 3 Shure SM58 Capsule Installation Replacement, Collar: passo 1, immagine 3 di 3
    • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
    • Be careful to not pull on the collar or you may rip the wires from the faceplate.
    Chiedi a FixBot
    Aggiungi Commento
  2. Shure SM58 Capsule Installation Replacement, Faceplate: passo 2, immagine 1 di 1
    • Remove the yellow and green wires from the face plate.
    • Note which side the yellow and green wires connect to.
    Chiedi a FixBot
    Aggiungi Commento
  3. Shure SM58 Capsule Installation Replacement: passo 3, immagine 1 di 2 Shure SM58 Capsule Installation Replacement: passo 3, immagine 2 di 2
    • Never open the microphone capsule. Attempting to open the capsule will likely result in permanent damage and make the microphone unusable.
    • Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
    Chiedi a FixBot
    Aggiungi Commento
  4. Shure SM58 Capsule Installation Replacement: passo 4, immagine 1 di 2 Shure SM58 Capsule Installation Replacement: passo 4, immagine 2 di 2
    • Slide the face plate over the connector.
    Chiedi a FixBot
    Aggiungi Commento
  5. Shure SM58 Capsule Installation Replacement, Capsule Installation: passo 5, immagine 1 di 2 Shure SM58 Capsule Installation Replacement, Capsule Installation: passo 5, immagine 2 di 2
    • Using an adjustable wrench, remove the nut and the washer behind the face plate by twisting the nut counterclockwise.
    Chiedi a FixBot
    Aggiungi Commento
  6. Shure SM58 Capsule Installation Replacement: passo 6, immagine 1 di 1
    • Hold the body of the microphone, right below the grille, in one hand. Using your other hand, rotate the grille clockwise.
    Chiedi a FixBot
    Aggiungi Commento
  7. Shure SM58 Capsule Installation Replacement: passo 7, immagine 1 di 1
    • Slide the grille off the top of the microphone once it is all the way loosened.
    Chiedi a FixBot
    Aggiungi Commento
  8. Shure SM58 Capsule Installation Replacement: passo 8, immagine 1 di 3 Shure SM58 Capsule Installation Replacement: passo 8, immagine 2 di 3 Shure SM58 Capsule Installation Replacement: passo 8, immagine 3 di 3
    • Hold the black plastic piece under the grille in one hand. In the other hand, hold the microphone collar.
    • Slowly, pull upward while twisting the black plastic piece clockwise.
    • Be careful not to scratch the copper microphone capsule. Another face plate may fall out when removing capsule.
    • Never open the microphone capsule. Attempting to repair the capsule will result in permanent damage.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Once installed, reassemble the microphone following the steps in reverse.
Altre 9 persone hanno completato questa guida.
nat coll
Membro da: 09/27/12
859 Reputazione
14 guide realizzate
Cal Poly, Team 7-53, Forte Fall 2012 Membro di Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Membri
33 guide realizzate
5Commenti sulla guida
Thanks for that,
Can i just replace the capsule as seen in the last picture?
Has it to be resoldered? Where do those very fine copper wires go?
Eanoid - Rispondi Condividi
It's been a few years since I made the guide and no longer have any microphones nearby to examen, but if I remember correctly, there is no soldering between the capsule and the housing. I believe the housing is soldered to the rest of the body with the silver leads at the bottom left of the picture.
Daniel Berger - Rispondi Condividi
Somehow the grill got really stuck and I want to replace it. It it screwed or is it as you've said - slidable?
arnold - Rispondi Condividi
You can unscrew just the grill.
Burke McQuinn - Rispondi Condividi
Hi, a bit unrelated but I accidentally twisted the black plastic piece slightly while everything was still intact. I turned it back though, did I damage the SM58 in any way?
Emje De - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 48
Ultimi 30 giorni: 231
Tutti i Tempi: 45,174
