Salta al contenuto principale
Sharp Aquos Crystal Screen Replacement
Cosa ti serve
  1. Sharp Aquos Crystal Screen Replacement, Back Panel: passo 1, immagine 1 di 3 Sharp Aquos Crystal Screen Replacement, Back Panel: passo 1, immagine 2 di 3 Sharp Aquos Crystal Screen Replacement, Back Panel: passo 1, immagine 3 di 3
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
    Chiedi a FixBot
    Aggiungi Commento
  2. Sharp Aquos Crystal Screen Replacement, USB Port: passo 2, immagine 1 di 2 Sharp Aquos Crystal Screen Replacement, USB Port: passo 2, immagine 2 di 2
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  3. Sharp Aquos Crystal Screen Replacement: passo 3, immagine 1 di 2 Sharp Aquos Crystal Screen Replacement: passo 3, immagine 2 di 2
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
    Chiedi a FixBot
    Aggiungi Commento
  4. Sharp Aquos Crystal Screen Replacement: passo 4, immagine 1 di 2 Sharp Aquos Crystal Screen Replacement: passo 4, immagine 2 di 2
    • Disconnect the wire by lifting it up with a plastic opening tool.
    Chiedi a FixBot
    Aggiungi Commento
  5. Sharp Aquos Crystal Screen Replacement: passo 5, immagine 1 di 3 Sharp Aquos Crystal Screen Replacement: passo 5, immagine 2 di 3 Sharp Aquos Crystal Screen Replacement: passo 5, immagine 3 di 3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
    Chiedi a FixBot
    Aggiungi Commento
  6. Sharp Aquos Crystal Screen Replacement: passo 6, immagine 1 di 1
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
    Chiedi a FixBot
    Aggiungi Commento
  7. Sharp Aquos Crystal Screen Replacement, Motherboard: passo 7, immagine 1 di 1
    • Peel off the black pieces of tape.
    Chiedi a FixBot
    Aggiungi Commento
  8. Sharp Aquos Crystal Screen Replacement: passo 8, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  9. Sharp Aquos Crystal Screen Replacement: passo 9, immagine 1 di 2 Sharp Aquos Crystal Screen Replacement: passo 9, immagine 2 di 2
    • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
    Chiedi a FixBot
    Aggiungi Commento
  10. Sharp Aquos Crystal Screen Replacement: passo 10, immagine 1 di 1
    • Peel the tape off with your hands.
    Chiedi a FixBot
    Aggiungi Commento
  11. Sharp Aquos Crystal Screen Replacement: passo 11, immagine 1 di 1
    • Lift the motherboard out with your hands.
    Chiedi a FixBot
    Aggiungi Commento
  12. Sharp Aquos Crystal Screen Replacement, Battery: passo 12, immagine 1 di 1
    • Peel off the tape holding the battery down.
    Chiedi a FixBot
    Aggiungi Commento
  13. Sharp Aquos Crystal Screen Replacement: passo 13, immagine 1 di 2 Sharp Aquos Crystal Screen Replacement: passo 13, immagine 2 di 2
    • Lift the battery out with your hands.
    Chiedi a FixBot
    Aggiungi Commento
  14. Sharp Aquos Crystal Screen Replacement, Screen: passo 14, immagine 1 di 1
    • Replace this component with the new one.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
1Commento della guida
Thanks! I did it!
Matteo Favero - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 19
Ultimi 30 giorni: 78
Tutti i Tempi: 11,265
