Introduzione
The LED screen on this device allows you to operate its purifier system. Use this as a guide to replace the screen if it is damaged
Cosa ti serve
Unscrew the one 1.2 cm screw holding the grate at the top with a TR10 Torx screwdriver.
Use a prying tool to carefully pry along the outer edges to disengage the inner retaining clips.
Remove the grate.
Remove the single Phillips screw on top of the device.
Lift up the plastic cover after removing the screw to replace the screen.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
