Salta al contenuto principale
Shank Button Replacement
Cosa ti serve
    1. Shank Button Replacement, Shank Button: passo 1, immagine 1 di 3 Shank Button Replacement, Shank Button: passo 1, immagine 2 di 3 Shank Button Replacement, Shank Button: passo 1, immagine 3 di 3
      • Remove your loose button (if necessary).
      • If the button is already missing, remove any loose threads from your garment.
      • Mark where the button was on the garment to hold place (a felt tip pen works fine, just keep the marking small)
      Chiedi a FixBot
      Aggiungi Commento
    2. Shank Button Replacement: passo 2, immagine 1 di 3 Shank Button Replacement: passo 2, immagine 2 di 3 Shank Button Replacement: passo 2, immagine 3 di 3
      • Measure out your thread. An easy measuring reference is the length of one arm fully extended.
      • Thread your needle.
      • Pull the thread until two equal parts are on either side of the needle.
      • Tie a knot in the end of your thread (both ends should be tied together creating a double thread).
      Chiedi a FixBot
      Aggiungi Commento
    3. Shank Button Replacement: passo 3, immagine 1 di 3 Shank Button Replacement: passo 3, immagine 2 di 3 Shank Button Replacement: passo 3, immagine 3 di 3
      • Insert your needle into the marked space where your needle should go on the top side of the garment (that way the button will hide your knot).
      • Pull the thread until the knot rests on the fabric.
      • Insert your needle into the shank on the back of your button.
      • Pull the thread until the button rests on the fabric.
      • Insert the needle back into the same space on your fabric. Repeat the above instructions 5 times or until the button is firmly attached.
      Chiedi a FixBot
      Aggiungi Commento
    4. Shank Button Replacement: passo 4, immagine 1 di 3 Shank Button Replacement: passo 4, immagine 2 di 3 Shank Button Replacement: passo 4, immagine 3 di 3
      • To tie off your thread, insert the needle back into the fabric near your previous stitches.
      • Pull thread until there is a small loop (do not pull flush with fabric).
      • Insert the needle into the thread loop and pull through.
      • Pull the thread until the loop closes and a knot is formed.
      Chiedi a FixBot
      Aggiungi Commento
    5. Shank Button Replacement: passo 5, immagine 1 di 3 Shank Button Replacement: passo 5, immagine 2 di 3 Shank Button Replacement: passo 5, immagine 3 di 3
      • Trim any excess thread from the button area.
      • Enjoy your newly repaired item!
      Chiedi a FixBot
      Aggiungi Commento
Linea Traguardo
Rebekah Kilpatrick
Membro da: 09/20/23
121 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 20
Ultimi 30 giorni: 139
Tutti i Tempi: 1,206
