Salta al contenuto principale
Samsung WB350F Menu/Control Buttons Replacement
Cosa ti serve
    1. Samsung WB350F Menu/Control Buttons Replacement, Rear Case: passo 1, immagine 1 di 3 Samsung WB350F Menu/Control Buttons Replacement, Rear Case: passo 1, immagine 2 di 3 Samsung WB350F Menu/Control Buttons Replacement, Rear Case: passo 1, immagine 3 di 3
      • Remove the wristlet strap.
      • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung WB350F Menu/Control Buttons Replacement: passo 2, immagine 1 di 3 Samsung WB350F Menu/Control Buttons Replacement: passo 2, immagine 2 di 3 Samsung WB350F Menu/Control Buttons Replacement: passo 2, immagine 3 di 3
      • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
      • There is one silver screw on the bottom and two black screws on each side.
      • Keep the screws together for an easier re-assembly later.
      Chiedi a FixBot
      Aggiungi Commento
    3. Samsung WB350F Menu/Control Buttons Replacement: passo 3, immagine 1 di 3 Samsung WB350F Menu/Control Buttons Replacement: passo 3, immagine 2 di 3 Samsung WB350F Menu/Control Buttons Replacement: passo 3, immagine 3 di 3
      • Open the case of the camera using your plastic opening tool.
      • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
      • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
      Chiedi a FixBot
      Aggiungi Commento
    4. Samsung WB350F Menu/Control Buttons Replacement: passo 4, immagine 1 di 1
      • Remove the plastic casing, exposing the inner workings of the camera.
      Chiedi a FixBot
      Aggiungi Commento
    1. Samsung WB350F Menu/Control Buttons Replacement, Screen: passo 5, immagine 1 di 2 Samsung WB350F Menu/Control Buttons Replacement, Screen: passo 5, immagine 2 di 2
      • Using your Phillips #000 Screwdriver, remove one 3.2 mm screw above the menu buttons panel.
      • Next, remove the two 3.2 mm Phillips #000 screws to the left of the menu buttons panel.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung WB350F Menu/Control Buttons Replacement: passo 6, immagine 1 di 1
      • Move the menu button panel to the right as well as the screen.
      • Be careful because each are connected to the camera by a ribbon.
      Chiedi a FixBot
      Aggiungi Commento
    3. Samsung WB350F Menu/Control Buttons Replacement: passo 7, immagine 1 di 1
      • Remove two more 3.2 mm screws on the silver panel using your Phillips #000 Screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    4. Samsung WB350F Menu/Control Buttons Replacement: passo 8, immagine 1 di 2 Samsung WB350F Menu/Control Buttons Replacement: passo 8, immagine 2 di 2
      • Remove the silver panel.
      Chiedi a FixBot
      Aggiungi Commento
    5. Samsung WB350F Menu/Control Buttons Replacement: passo 9, immagine 1 di 2 Samsung WB350F Menu/Control Buttons Replacement: passo 9, immagine 2 di 2
      • Flip the screen back over.
      • Using the plastic open tool, flip open the black retaining plastic piece holding the larger ribbon in place.
      Chiedi a FixBot
      Aggiungi Commento
    6. Samsung WB350F Menu/Control Buttons Replacement: passo 10, immagine 1 di 2 Samsung WB350F Menu/Control Buttons Replacement: passo 10, immagine 2 di 2
      • Carefully detach both ribbons by gently pulling one at a time.
      • The thinner ribbon isn't secured with a connector and you are able to pull it straight out.
      • Be sure to pull gently as you do not want to break either ribbon.
      Chiedi a FixBot
      Aggiungi Commento
    1. Samsung WB350F Menu/Control Buttons Replacement, Menu/Control Buttons: passo 11, immagine 1 di 3 Samsung WB350F Menu/Control Buttons Replacement, Menu/Control Buttons: passo 11, immagine 2 di 3 Samsung WB350F Menu/Control Buttons Replacement, Menu/Control Buttons: passo 11, immagine 3 di 3
      • Gently pull the ribbon in order to remove the menu/control button panel.
      • The ribbon isn't secured with a connector and you are able to pull it straight out.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 41
Tutti i Tempi: 1,720
