Salta al contenuto principale
Samsung UBD-KM85C WiFi Module Replacement
Cosa ti serve
  1. Samsung UBD-KM85C WiFi Module Replacement, Outer Shell: passo 1, immagine 1 di 1
    • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung UBD-KM85C WiFi Module Replacement: passo 2, immagine 1 di 2 Samsung UBD-KM85C WiFi Module Replacement: passo 2, immagine 2 di 2
    • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung UBD-KM85C WiFi Module Replacement: passo 3, immagine 1 di 3 Samsung UBD-KM85C WiFi Module Replacement: passo 3, immagine 2 di 3 Samsung UBD-KM85C WiFi Module Replacement: passo 3, immagine 3 di 3
    • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung UBD-KM85C WiFi Module Replacement: passo 4, immagine 1 di 1
    • Remove the cover from the device.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung UBD-KM85C WiFi Module Replacement, WiFi Module: passo 5, immagine 1 di 2 Samsung UBD-KM85C WiFi Module Replacement, WiFi Module: passo 5, immagine 2 di 2
    • The wifi module is clipped into place in the corner of the device. There are no screws or adhesives holding it down.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung UBD-KM85C WiFi Module Replacement: passo 6, immagine 1 di 3 Samsung UBD-KM85C WiFi Module Replacement: passo 6, immagine 2 di 3 Samsung UBD-KM85C WiFi Module Replacement: passo 6, immagine 3 di 3
    • There is one wire plugged into the Wi-Fi module that has to be removed in order to allow the range of motion to remove the module. Simply pinch the white plastic end of the wire and pull it out.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung UBD-KM85C WiFi Module Replacement: passo 7, immagine 1 di 3 Samsung UBD-KM85C WiFi Module Replacement: passo 7, immagine 2 di 3 Samsung UBD-KM85C WiFi Module Replacement: passo 7, immagine 3 di 3
    • Pull on the module from the sides and be sure not to pull on the stand that is screwed into the frame. The Wi-Fi module can then be pulled out of the clips and off the stand.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Baylor, Team S2-G1, Johnson Spring 2018 Membro di Baylor, Team S2-G1, Johnson Spring 2018
BU-JOHNSON-S18S2G1
3 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 9
Ultimi 30 giorni: 33
Tutti i Tempi: 1,104
