Salta al contenuto principale
Samsung Stratosphere Front Camera Replacement
Cosa ti serve
  1. Samsung Stratosphere Front Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Using your fingers, pry along the groove at the top of the phone.
    • Pull back on the rear casing until it comes free from the device.
    • The casing will make a cracking sound as it is removed.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Stratosphere Front Camera Replacement: passo 2, immagine 1 di 1
    • With your fingers, pry from the bottom of the battery to loosen it.
    • Lift away to remove the battery from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Stratosphere Front Camera Replacement, Motherboard: passo 3, immagine 1 di 1
    • Locate the red and white sim card located above the battery housing.
    • Remove the sim card by sliding it downwards from its slot with your fingers.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Stratosphere Front Camera Replacement: passo 4, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
    • Once loosened, some screws may get stuck in the casing. Use tweezers to remove them.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Stratosphere Front Camera Replacement: passo 5, immagine 1 di 1
    • Pry around the rear panel with a plastic opening tool to loosen it.
    • Prying too deeply may damage delicate components inside the phone.
    • Remove the rear panel from the phone with your fingers.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Stratosphere Front Camera Replacement: passo 6, immagine 1 di 1
    • Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung Stratosphere Front Camera Replacement: passo 7, immagine 1 di 2 Samsung Stratosphere Front Camera Replacement: passo 7, immagine 2 di 2
    • Locate the flex cable attachment at the tab with a green arrow printed on top.
    • Pry from the side the arrow is pointing with your fingers.
    • The cable will audibly snap as it is removed from its attachment.
    • Let the cable hang loosely to the side of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  8. Samsung Stratosphere Front Camera Replacement: passo 8, immagine 1 di 1
    • Pull the motherboard up from the side opposite the loose flex cable.
    • If necessary, use a plastic opening tool to separate the motherboard from the key pad underneath.
    • Lift to remove the motherboard from the device.
    Chiedi a FixBot
    Aggiungi Commento
  9. Samsung Stratosphere Front Camera Replacement, Front Camera: passo 9, immagine 1 di 1
    • Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
    • Pry the keyboard away from the casing with the plastic opening tool.
    • The keyboard should come off with almost no force at all.
    Chiedi a FixBot
    Aggiungi Commento
  10. Samsung Stratosphere Front Camera Replacement: passo 10, immagine 1 di 1
    • Remove the 7 silver 2mm screws attaching the silver metal plate to the rear panel with the Phillips #000 Screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  11. Samsung Stratosphere Front Camera Replacement: passo 11, immagine 1 di 1
    • Use the plastic opening tool to carefully loosen the golden metal plate.
    • The golden metal plate is stuck to the rear panel with a strong adhesive, so a moderate amount of force may be needed.
    Chiedi a FixBot
    Aggiungi Commento
  12. Samsung Stratosphere Front Camera Replacement: passo 12, immagine 1 di 1
    • Lift the gold plate with your fingers, repositioning it to slide through the keyboard casing underneath.
    • Carefully take off the keyboard casing with your fingers.
    • The golden metal plate should fit through the wide slot of the casing.
    Chiedi a FixBot
    Aggiungi Commento
  13. Samsung Stratosphere Front Camera Replacement: passo 13, immagine 1 di 1
    • Slide the silver metal plate down and away from the to the flex cable and gold metal plate.
    • The metal plate is attached to springs that offer a small amount of resistance, so it will snap into place.
    Chiedi a FixBot
    Aggiungi Commento
  14. Samsung Stratosphere Front Camera Replacement: passo 14, immagine 1 di 1
    • Unscrew the 4 black 3mm screws from the rear panel with the Phillips #000 Screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  15. Samsung Stratosphere Front Camera Replacement: passo 15, immagine 1 di 2 Samsung Stratosphere Front Camera Replacement: passo 15, immagine 2 di 2
    • Insert the plastic opening tool into the groove at the top of the rear panel.
    • Firmly slide the plastic opening tool all around the rear panel. The panel will audibly snap as it comes apart.
    • These 2 pieces are attached well, so a significant amount of force is needed to separate them.
    Chiedi a FixBot
    Aggiungi Commento
  16. Samsung Stratosphere Front Camera Replacement: passo 16, immagine 1 di 1
    • Lift the flex cable and position it so the part containing the metal plate can come free.
    • Pull the part containing the metal plate away from the rest of the rear panel.
    Chiedi a FixBot
    Aggiungi Commento
  17. Samsung Stratosphere Front Camera Replacement: passo 17, immagine 1 di 2 Samsung Stratosphere Front Camera Replacement: passo 17, immagine 2 di 2
    • Use tweezers to loosen the front-facing camera from the plastic casing.
    • Pull the black rectangular piece, attached to the front facing camera, away from the rear panel.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Ryan
Membro da: 10/20/13
375 Reputazione
2 guide realizzate
Cal Poly, Team 11-32, Amido Fall 2013 Membro di Cal Poly, Team 11-32, Amido Fall 2013
CPSU-AMIDO-F13S11G32
4 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 5
Ultimi 30 giorni: 26
Tutti i Tempi: 792
