Salta al contenuto principale
Samsung Solstice Battery Replacement
Cosa ti serve
  1. Samsung Solstice Battery Replacement, Removing the back cover: passo 1, immagine 1 di 3 Samsung Solstice Battery Replacement, Removing the back cover: passo 1, immagine 2 di 3 Samsung Solstice Battery Replacement, Removing the back cover: passo 1, immagine 3 di 3
    • Gently slide the cover off of the phone by pushing it upwards, in the direction of the small arrow on the back cover.
    • Set the cover off to the side once you have removed it.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Solstice Battery Replacement, Removing the battery: passo 2, immagine 1 di 3 Samsung Solstice Battery Replacement, Removing the battery: passo 2, immagine 2 di 3 Samsung Solstice Battery Replacement, Removing the battery: passo 2, immagine 3 di 3
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool in between the rear end of the battery and the plastic frame.
    • Pry the battery up out of its recess and away from the phone.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 23
Tutti i Tempi: 649
