Salta al contenuto principale
Samsung SPEX SCH-R210 antenna Replacement
Cosa ti serve
  1. Samsung SPEX SCH-R210 antenna Replacement, Back Cover: passo 1, immagine 1 di 3 Samsung SPEX SCH-R210 antenna Replacement, Back Cover: passo 1, immagine 2 di 3 Samsung SPEX SCH-R210 antenna Replacement, Back Cover: passo 1, immagine 3 di 3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung SPEX SCH-R210 antenna Replacement, Battery: passo 2, immagine 1 di 1
    • Locate the access notch at the end of the battery compartment.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung SPEX SCH-R210 antenna Replacement: passo 3, immagine 1 di 1
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung SPEX SCH-R210 antenna Replacement, Antenna: passo 4, immagine 1 di 2 Samsung SPEX SCH-R210 antenna Replacement, Antenna: passo 4, immagine 2 di 2
    • After removing the battery, unscrew the 4 3/16" screws on the black plastic cover with the Phillips #00 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung SPEX SCH-R210 antenna Replacement: passo 5, immagine 1 di 2 Samsung SPEX SCH-R210 antenna Replacement: passo 5, immagine 2 di 2
    • Remove the headphone cover from the left side and the volume cover from the right side of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung SPEX SCH-R210 antenna Replacement: passo 6, immagine 1 di 1
    • Remove the black plastic cover from the back of the phone. This may take a little effort to remove.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung SPEX SCH-R210 antenna Replacement: passo 7, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • The antenna is located on the opposite side of the black plastic cover. Use the tweezers to remove the antenna.
    Chiedi a FixBot
    Aggiungi Commento
  8. Samsung SPEX SCH-R210 antenna Replacement: passo 8, immagine 1 di 1
    • The gray rubber antenna cover will need to come out as well. Use the tweezers to remove the gray cover.
    Chiedi a FixBot
    Aggiungi Commento
  9. Samsung SPEX SCH-R210 antenna Replacement: passo 9, immagine 1 di 1
    • Replace with a new antenna.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Susan
Membro da: 07/11/13
331 Reputazione
3 guide realizzate
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Membro di WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 5
Ultimi 30 giorni: 19
Tutti i Tempi: 533
