Salta al contenuto principale
Samsung SPEX SCH-R210 Keypad Replacement
Cosa ti serve
  1. Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: passo 1, immagine 1 di 3 Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: passo 1, immagine 2 di 3 Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: passo 1, immagine 3 di 3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung SPEX SCH-R210 Keypad Replacement, Battery: passo 2, immagine 1 di 1
    • Locate the access notch at the end of the battery compartment.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung SPEX SCH-R210 Keypad Replacement: passo 3, immagine 1 di 1
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung SPEX SCH-R210 Keypad Replacement, Keypad: passo 4, immagine 1 di 2 Samsung SPEX SCH-R210 Keypad Replacement, Keypad: passo 4, immagine 2 di 2
    • Remove the four 4.8 mm screws from the midframe using a Phillips #00 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung SPEX SCH-R210 Keypad Replacement: passo 5, immagine 1 di 1
    • Remove the headphone cover from the left side of the midframe.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung SPEX SCH-R210 Keypad Replacement: passo 6, immagine 1 di 1
    • Remove the volume cover from the right side of the midframe.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung SPEX SCH-R210 Keypad Replacement: passo 7, immagine 1 di 1
    • Use your hands to separate the midframe from the rest of the phone.
    • This may take a little effort to remove.
    Chiedi a FixBot
    Aggiungi Commento
  8. Samsung SPEX SCH-R210 Keypad Replacement: passo 8, immagine 1 di 1
    • Use a 1.5 mm hex screwdriver to remove the three 2.4 mm screws around the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  9. Samsung SPEX SCH-R210 Keypad Replacement: passo 9, immagine 1 di 1
    • Lift the metal plate off of the motherboard and set it aside.
    Chiedi a FixBot
    Aggiungi Commento
  10. Samsung SPEX SCH-R210 Keypad Replacement: passo 10, immagine 1 di 2 Samsung SPEX SCH-R210 Keypad Replacement: passo 10, immagine 2 di 2
    • Push on the white plastic tabs and the keypad at the same time to remove the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  11. Samsung SPEX SCH-R210 Keypad Replacement: passo 11, immagine 1 di 2 Samsung SPEX SCH-R210 Keypad Replacement: passo 11, immagine 2 di 2
    • Turn the phone over to its front side.
    • Apply pressure on the keypad.
    • The keypad will come out easily.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Susan
Membro da: 07/11/13
331 Reputazione
3 guide realizzate
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Membro di WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Membri
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 9
Ultimi 30 giorni: 33
Tutti i Tempi: 639
