Salta al contenuto principale
Samsung POWERbot R7070 Left Driving Wheel Replacement
Cosa ti serve
    1. Samsung POWERbot R7070 Left Driving Wheel  Replacement, Battery: passo 1, immagine 1 di 1
      • Turn the emergency switch off.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 2, immagine 1 di 2 Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 2, immagine 2 di 2
      • Remove the two exposed screws on the top right of the device.
      Chiedi a FixBot
      Aggiungi Commento
    3. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 3, immagine 1 di 1
      • Lift the cover plate to expose the battery.
      Chiedi a FixBot
      Aggiungi Commento
    4. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 4, immagine 1 di 2 Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 4, immagine 2 di 2
      • Using one hand, pinch the white plastic connector where the battery's wiring connects the POWERbot. Pull up to disconnect.
      Chiedi a FixBot
      Aggiungi Commento
    5. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 5, immagine 1 di 2 Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 5, immagine 2 di 2
      • Lift the battery from the right side, up and out of its compartment.
      Chiedi a FixBot
      Aggiungi Commento
    1. Samsung POWERbot R7070 Left Driving Wheel  Replacement, Motor: passo 6, immagine 1 di 2 Samsung POWERbot R7070 Left Driving Wheel  Replacement, Motor: passo 6, immagine 2 di 2
      • Unscrew the two silver 1.5 cm screws on the left and right side of the battery compartment.
      • Remove the two 1.5 cm screws above the yellow sliding lock tabs.
      • Remove the two 1.2 cm screws in the brush compartment.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 7, immagine 1 di 2 Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 7, immagine 2 di 2
      • With moderate force, separate the silver top from the black bottom of the vacuum.
      • The cover will only separate a few inches as the two halves are connected by wires.
      Chiedi a FixBot
      Aggiungi Commento
    3. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 8, immagine 1 di 1
      • Disconnect the white and red wired connector attached to the top half of the base of the vacuum by squeezing the connector and pulling up.
      Chiedi a FixBot
      Aggiungi Commento
    4. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 9, immagine 1 di 1
      • Pinching the top and bottom of the black wired connector, pull outward, fully detaching the top from the bottom of the device.
      Chiedi a FixBot
      Aggiungi Commento
    5. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 10, immagine 1 di 1
      • Detach the wide circuit connector on the left side by pinching and pressing down on the right and left side of the clip, pulling the connector out.
      • Pull the connector out by the left and right side of the white clip and not by the wires.
      Chiedi a FixBot
      Aggiungi Commento
    6. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 11, immagine 1 di 2 Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 11, immagine 2 di 2
      • Remove the four 1.2 cm screws.
      • Remove the single 0.8 cm screw.
      Chiedi a FixBot
      Aggiungi Commento
    7. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 12, immagine 1 di 1
      • Remove the two 1.5 cm screws on the motor chamber.
      Chiedi a FixBot
      Aggiungi Commento
    8. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 13, immagine 1 di 2 Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 13, immagine 2 di 2
      • Lift the motor by grabbing the body of the motor, lifting upward.
      • With the screws removed from the motor chamber the top of the motor chamber will pop open.
      Chiedi a FixBot
      Aggiungi Commento
    1. Samsung POWERbot R7070 Left Driving Wheel  Replacement, Left Driving Wheel: passo 14, immagine 1 di 2 Samsung POWERbot R7070 Left Driving Wheel  Replacement, Left Driving Wheel: passo 14, immagine 2 di 2
      • Unscrew the two screws securing the left and right ends of the wheel casing to the base of the vacuum.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 15, immagine 1 di 1
      • Unscrew the screws securing the black plastic piece to the left of the wheel casing.
      • This piece is not part of the wheel casing but must be moved out of the way to remove the wheel.
      • Lift the wheel casing out of the vacuum base.
      Chiedi a FixBot
      Aggiungi Commento
    3. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 16, immagine 1 di 2 Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 16, immagine 2 di 2
      • Arrange the wheel so that the spring is fully retracted.
      • Unhook one edge of the spring by carefully pulling the spring towards the hook.
      • With the spring unhooked, remove the spring from the wheel casing.
      Chiedi a FixBot
      Aggiungi Commento
    4. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 17, immagine 1 di 3 Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 17, immagine 2 di 3 Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 17, immagine 3 di 3
      • Remove the screws that are fastening the two halves of the wheel casing together.
      Chiedi a FixBot
      Aggiungi Commento
    5. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 18, immagine 1 di 2 Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 18, immagine 2 di 2
      • Open wheel casing.
      Chiedi a FixBot
      Aggiungi Commento
    6. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 19, immagine 1 di 1
      • Unscrew the black 1 cm screw securing the center of the wheel to the remaining half of the wheel casing.
      Chiedi a FixBot
      Aggiungi Commento
    7. Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 20, immagine 1 di 2 Samsung POWERbot R7070 Left Driving Wheel  Replacement: passo 20, immagine 2 di 2
      • Remove the wheel.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
CSU Fullerton, Team S2-G8, Bruce Fall 2017 Membro di CSU Fullerton, Team S2-G8, Bruce Fall 2017
CSUF-BRUCE-F17S2G8
3 Membri
15 guide realizzate
2Commenti sulla guida
Where can you find the replacement left driving wheel? are all the model the same?
ghvolleyball - Rispondi Condividi
My left wheel seams to have sand in the gear box now and won’t turn. I need a replacement part or assembly for a R7065 Powerbot LH wheel gear box, which is very similar to the R7070. As far as I can see (I have one of each) the R7065 has two rubber beaters and two brush beaters where as the R7070 has 4 rubber beaters.
Steven Nicholas - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 23
Tutti i Tempi: 3,900
