Salta al contenuto principale
Samsung Jack Keyboard Replacement
Cosa ti serve
  1. Samsung Jack Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Jack Keyboard Replacement: passo 2, immagine 1 di 1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Jack Keyboard Replacement, Rear Case: passo 3, immagine 1 di 1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Jack Keyboard Replacement: passo 4, immagine 1 di 3 Samsung Jack Keyboard Replacement: passo 4, immagine 2 di 3 Samsung Jack Keyboard Replacement: passo 4, immagine 3 di 3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Jack Keyboard Replacement: passo 5, immagine 1 di 1
    • Lift the rear case off of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Jack Keyboard Replacement, Antenna: passo 6, immagine 1 di 1
    • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung Jack Keyboard Replacement: passo 7, immagine 1 di 3 Samsung Jack Keyboard Replacement: passo 7, immagine 2 di 3 Samsung Jack Keyboard Replacement: passo 7, immagine 3 di 3
    • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
    • Use a spudger to remove the wire connector under the antenna.
    Chiedi a FixBot
    Aggiungi Commento
  8. Samsung Jack Keyboard Replacement, Speaker: passo 8, immagine 1 di 1
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  9. Samsung Jack Keyboard Replacement: passo 9, immagine 1 di 2 Samsung Jack Keyboard Replacement: passo 9, immagine 2 di 2
    • Use the spudger to detach the speaker ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  10. Samsung Jack Keyboard Replacement: passo 10, immagine 1 di 1
    • Lift the speaker out of its compartment.
    Chiedi a FixBot
    Aggiungi Commento
  11. Samsung Jack Keyboard Replacement, Motherboard: passo 11, immagine 1 di 1
    • Remove the power and volume buttons on the right side of the Motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  12. Samsung Jack Keyboard Replacement: passo 12, immagine 1 di 2 Samsung Jack Keyboard Replacement: passo 12, immagine 2 di 2
    • Use a spudger to detach the camera ribbon cable.
    • Lift the camera off of the Motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  13. Samsung Jack Keyboard Replacement: passo 13, immagine 1 di 2 Samsung Jack Keyboard Replacement: passo 13, immagine 2 di 2
    • Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  14. Samsung Jack Keyboard Replacement: passo 14, immagine 1 di 3 Samsung Jack Keyboard Replacement: passo 14, immagine 2 di 3 Samsung Jack Keyboard Replacement: passo 14, immagine 3 di 3
    • Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
    • Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
    Chiedi a FixBot
    Aggiungi Commento
  15. Samsung Jack Keyboard Replacement: passo 15, immagine 1 di 2 Samsung Jack Keyboard Replacement: passo 15, immagine 2 di 2
    • There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
    • Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
    • Use a spudger to disconnect the Motherboard ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  16. Samsung Jack Keyboard Replacement: passo 16, immagine 1 di 1
    • Lift the Motherboard off of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  17. Samsung Jack Keyboard Replacement, Keyboard: passo 17, immagine 1 di 3 Samsung Jack Keyboard Replacement, Keyboard: passo 17, immagine 2 di 3 Samsung Jack Keyboard Replacement, Keyboard: passo 17, immagine 3 di 3
    • The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
    • Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
    Chiedi a FixBot
    Aggiungi Commento
  18. Samsung Jack Keyboard Replacement: passo 18, immagine 1 di 2 Samsung Jack Keyboard Replacement: passo 18, immagine 2 di 2
    • Lift up the LCD frame.
    Chiedi a FixBot
    Aggiungi Commento
  19. Samsung Jack Keyboard Replacement: passo 19, immagine 1 di 3 Samsung Jack Keyboard Replacement: passo 19, immagine 2 di 3 Samsung Jack Keyboard Replacement: passo 19, immagine 3 di 3
    • The keyboard ribbon cable passes through the LCD frame. Be careful not to rip the ribbon cable when removing the keyboard.
    • The keyboard and directional keys are glued separately to the LCD frame.
    • Insert the spudger between the keyboard and the frame.
    • Peel the keyboard off by sliding the spudger back and forth across the LCD frame.
    Chiedi a FixBot
    Aggiungi Commento
  20. Samsung Jack Keyboard Replacement: passo 20, immagine 1 di 3 Samsung Jack Keyboard Replacement: passo 20, immagine 2 di 3 Samsung Jack Keyboard Replacement: passo 20, immagine 3 di 3
    • Insert the spudger between the directional keys and the frame.
    • Peel the directional keys off by sliding the spudger back and forth across the LCD frame.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 24-57, Amido Spring 2011 Membro di Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 25
Tutti i Tempi: 2,386
