Salta al contenuto principale
Samsung Impression Keyboard Replacement
Cosa ti serve
  1. Samsung Impression Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Impression Keyboard Replacement: passo 2, immagine 1 di 2 Samsung Impression Keyboard Replacement: passo 2, immagine 2 di 2
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Impression Keyboard Replacement, Back Cover: passo 3, immagine 1 di 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Impression Keyboard Replacement: passo 4, immagine 1 di 1
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Impression Keyboard Replacement, Circuit Board: passo 5, immagine 1 di 1
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Impression Keyboard Replacement: passo 6, immagine 1 di 2 Samsung Impression Keyboard Replacement: passo 6, immagine 2 di 2
    • Gently tug the black and blue ribbon upwards to release the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung Impression Keyboard Replacement, Antenna: passo 7, immagine 1 di 2 Samsung Impression Keyboard Replacement, Antenna: passo 7, immagine 2 di 2
    • Use a Phillips screwdriver to remove the six 3.5 mm screws by rotating.
    • The antenna assembly will snap off.
    Chiedi a FixBot
    Aggiungi Commento
  8. Samsung Impression Keyboard Replacement, Keyboard: passo 8, immagine 1 di 1
    • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
    • The screws are 2.7mm in length.
    • The bottom black end cap will snap out.
    Chiedi a FixBot
    Aggiungi Commento
  9. Samsung Impression Keyboard Replacement: passo 9, immagine 1 di 2 Samsung Impression Keyboard Replacement: passo 9, immagine 2 di 2
    • Remove the six 2.7 mm screws holding the silver plate on and set aside (fig. 1).
    • Separate the silver plate and phone frame (fig. 2).
    Chiedi a FixBot
    Aggiungi Commento
  10. Samsung Impression Keyboard Replacement: passo 10, immagine 1 di 1
    • The silver piece you are left with is the physical keyboard assembly.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 8-10, Regan Spring 2011 Membro di Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Membri
34 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 20
Tutti i Tempi: 2,692
