Salta al contenuto principale
Samsung Impression Digitizer or Front Buttons Replacement
Cosa ti serve
  1. Samsung Impression Digitizer or Front Buttons Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Impression Digitizer or Front Buttons Replacement: passo 2, immagine 1 di 2 Samsung Impression Digitizer or Front Buttons Replacement: passo 2, immagine 2 di 2
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Impression Digitizer or Front Buttons Replacement, Back Cover: passo 3, immagine 1 di 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Impression Digitizer or Front Buttons Replacement: passo 4, immagine 1 di 1
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Impression Digitizer or Front Buttons Replacement, Circuit Board: passo 5, immagine 1 di 1
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Impression Digitizer or Front Buttons Replacement: passo 6, immagine 1 di 2 Samsung Impression Digitizer or Front Buttons Replacement: passo 6, immagine 2 di 2
    • Gently tug the black and blue ribbon upwards to release the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung Impression Digitizer or Front Buttons Replacement, Keyboard: passo 7, immagine 1 di 1
    • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
    • The screws are 2.7mm in length.
    • The bottom black end cap will snap out.
    Chiedi a FixBot
    Aggiungi Commento
  8. Samsung Impression Digitizer or Front Buttons Replacement: passo 8, immagine 1 di 2 Samsung Impression Digitizer or Front Buttons Replacement: passo 8, immagine 2 di 2
    • Remove the six 2.7 mm screws holding the silver plate on and set aside (fig. 1).
    • Separate the silver plate and phone frame (fig. 2).
    Chiedi a FixBot
    Aggiungi Commento
  9. Samsung Impression Digitizer or Front Buttons Replacement: passo 9, immagine 1 di 1
    • The silver piece you are left with is the physical keyboard assembly.
    Chiedi a FixBot
    Aggiungi Commento
  10. Samsung Impression Digitizer or Front Buttons Replacement, LCD Flex Cable: passo 10, immagine 1 di 2 Samsung Impression Digitizer or Front Buttons Replacement, LCD Flex Cable: passo 10, immagine 2 di 2
    • Remove the 3 screws holding down the flex cable.
    • The two screws on the black frame are 2.0 mm in length.
    • The top right screw that goes through the circle port on the flex cable is 2.3 mm.
    • Remove the keyboard slider frame. The flex cable should be exposed, but not free.
    Chiedi a FixBot
    Aggiungi Commento
  11. Samsung Impression Digitizer or Front Buttons Replacement: passo 11, immagine 1 di 1
    • Remove the four 3.5 mm outer screws.
    Chiedi a FixBot
    Aggiungi Commento
  12. Samsung Impression Digitizer or Front Buttons Replacement: passo 12, immagine 1 di 3 Samsung Impression Digitizer or Front Buttons Replacement: passo 12, immagine 2 di 3 Samsung Impression Digitizer or Front Buttons Replacement: passo 12, immagine 3 di 3
    • Slide the phone apart and remove the 3.5 mm screw on the top middle (fig. 1).
    • Remove the outer shell by prying the edges off with your fingers or a small screwdriver (fig. 2).
    • The device will now be in two pieces (fig. 3).
    Chiedi a FixBot
    Aggiungi Commento
  13. Samsung Impression Digitizer or Front Buttons Replacement: passo 13, immagine 1 di 2 Samsung Impression Digitizer or Front Buttons Replacement: passo 13, immagine 2 di 2
    • Lift the tab underneath the blue tape and gently pull the flex cable (fig. 1).
    • The flex cable will now be completely free (fig. 2).
    Chiedi a FixBot
    Aggiungi Commento
  14. Samsung Impression Digitizer or Front Buttons Replacement, Ear Speaker: passo 14, immagine 1 di 1
    • Remove the 2.3 mm screw.
    • Lift the black tab at the end of the ribbon.
    • Gently pull the speaker and ribbon free.
    Chiedi a FixBot
    Aggiungi Commento
  15. Samsung Impression Digitizer or Front Buttons Replacement, LCD: passo 15, immagine 1 di 2 Samsung Impression Digitizer or Front Buttons Replacement, LCD: passo 15, immagine 2 di 2
    • Lift the remaining two tabs and free their respective ribbon cables.
    • Gently pry the screen away from the housing.
    • Be careful with this step as you are in direct contact with the LCD screen.
    Chiedi a FixBot
    Aggiungi Commento
  16. Samsung Impression Digitizer or Front Buttons Replacement, Digitizer or Front Buttons: passo 16, immagine 1 di 1
    • If replacing the front buttons, remove the assembly at the bottom of the front panel
    • The digitizer is now free to be pulled out from the front housing.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 8-10, Regan Spring 2011 Membro di Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Membri
34 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 27
Tutti i Tempi: 7,237
