Salta al contenuto principale
Samsung Impression Camera Replacement
Cosa ti serve
  1. Samsung Impression Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Impression Camera Replacement: passo 2, immagine 1 di 2 Samsung Impression Camera Replacement: passo 2, immagine 2 di 2
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Impression Camera Replacement, Back Cover: passo 3, immagine 1 di 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Impression Camera Replacement: passo 4, immagine 1 di 1
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Impression Camera Replacement, Circuit Board: passo 5, immagine 1 di 1
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Impression Camera Replacement: passo 6, immagine 1 di 2 Samsung Impression Camera Replacement: passo 6, immagine 2 di 2
    • Gently tug the black and blue ribbon upwards to release the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung Impression Camera Replacement, Camera: passo 7, immagine 1 di 2 Samsung Impression Camera Replacement, Camera: passo 7, immagine 2 di 2
    • Turn the circuit board over.
    • The bottom of the camera will have a gold ribbon coming out of it which attaches to the circuit board.
    • Pull upwards on the blue rectangle where the gold ribbon ends. This will remove the camera from the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 8-10, Regan Spring 2011 Membro di Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Membri
34 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 22
Tutti i Tempi: 1,907
