Salta al contenuto principale
Samsung Gravity TXT Screen Replacement
Cosa ti serve
  1. Samsung Gravity TXT Screen Replacement, Battery: passo 1, immagine 1 di 2 Samsung Gravity TXT Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Gravity TXT Screen Replacement: passo 2, immagine 1 di 1
    • Lift the back cover away from the main body of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Gravity TXT Screen Replacement: passo 3, immagine 1 di 1
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Gravity TXT Screen Replacement, SIM Card: passo 4, immagine 1 di 3 Samsung Gravity TXT Screen Replacement, SIM Card: passo 4, immagine 2 di 3 Samsung Gravity TXT Screen Replacement, SIM Card: passo 4, immagine 3 di 3
    • Using your finger, push the SIM Card down and slide out of the slot.
    • Slide the SIM card out enough to grab it firmly.
    • Remove the SIM card away from the phone.
    • Follow the visual on the bottom of the SIM card slot to put the SIM card back in the correct orientation.
    • When sliding the SIM Card back in the slot, make sure the card goes all the way in the slot until it hits the stopper.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Gravity TXT Screen Replacement, microSD Card: passo 5, immagine 1 di 3 Samsung Gravity TXT Screen Replacement, microSD Card: passo 5, immagine 2 di 3 Samsung Gravity TXT Screen Replacement, microSD Card: passo 5, immagine 3 di 3
    • Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
    • The removal of the battery is not required for this operation; therefore, step 3 can be skipped if just replacing the microSD card.
    • After the click, release the microSD card to allow it to pop out.
    • Remove the microSD card from its slot
    • When placing the microSD card back in the phone, make sure the card clicks in place.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Gravity TXT Screen Replacement, Plastic Back Frame: passo 6, immagine 1 di 1
    • Remove the six 3 mm #00 Phillips screws in the plastic back frame.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung Gravity TXT Screen Replacement: passo 7, immagine 1 di 3 Samsung Gravity TXT Screen Replacement: passo 7, immagine 2 di 3 Samsung Gravity TXT Screen Replacement: passo 7, immagine 3 di 3
    • Slide the keyboard out.
    • Use a Jimmy to separate a small segment of the plastic back frame from rest of the phone.
    • Starting at the bottom of the keyboard is recommended.
    • Slide an opening pick around the rest of the seam, starting at the gap just created with the Jimmy.
    • You will have to slide the keyboard back in to separate the back frame from the top have of the keyboard slider.
    • Lift the plastic back frame away.
    Chiedi a FixBot
    Aggiungi Commento
  8. Samsung Gravity TXT Screen Replacement, Motherboard: passo 8, immagine 1 di 1
    • Remove the two 3 mm Phillips #00 screws securing the motherboard to the front panel.
    • Do not try to pull the motherboad out just yet. The display data cable needs to be disconnected from the motherboad first.
    Chiedi a FixBot
    Aggiungi Commento
  9. Samsung Gravity TXT Screen Replacement: passo 9, immagine 1 di 3 Samsung Gravity TXT Screen Replacement: passo 9, immagine 2 di 3 Samsung Gravity TXT Screen Replacement: passo 9, immagine 3 di 3
    • Use your finger nail to disconnect the display data cable from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  10. Samsung Gravity TXT Screen Replacement: passo 10, immagine 1 di 2 Samsung Gravity TXT Screen Replacement: passo 10, immagine 2 di 2
    • Carefully lift the main motherboard assembly away from the front panel.
    Chiedi a FixBot
    Aggiungi Commento
  11. Samsung Gravity TXT Screen Replacement, Keyboard: passo 11, immagine 1 di 1
    • Take the keyboard off of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  12. Samsung Gravity TXT Screen Replacement, Screen: passo 12, immagine 1 di 3 Samsung Gravity TXT Screen Replacement, Screen: passo 12, immagine 2 di 3 Samsung Gravity TXT Screen Replacement, Screen: passo 12, immagine 3 di 3
    • Lift the ribbon off the plastic inner frame.
    • You may have to warm the adhesive using an iOpener to avoid damaging the ribbon.
    • Remove the six 1.2 mm #00 screws from the inner plastic frame.
    • Slide the ribbon through the slot on the inner frame while pulling the frame away.
    Chiedi a FixBot
    Aggiungi Commento
  13. Samsung Gravity TXT Screen Replacement: passo 13, immagine 1 di 1
    • Remove the four 2.4 mm #00 Phillips screws.
    Chiedi a FixBot
    Aggiungi Commento
  14. Samsung Gravity TXT Screen Replacement: passo 14, immagine 1 di 3 Samsung Gravity TXT Screen Replacement: passo 14, immagine 2 di 3 Samsung Gravity TXT Screen Replacement: passo 14, immagine 3 di 3
    • Use a opening pick to separate the plastic back casing from the front of the phone by running it along the seam between the two.
    • Lift casing slightly away while sliding the ribbon through the slot in the casing.
    Chiedi a FixBot
    Aggiungi Commento
  15. Samsung Gravity TXT Screen Replacement: passo 15, immagine 1 di 2 Samsung Gravity TXT Screen Replacement: passo 15, immagine 2 di 2
    • Use a spudger to get underneath and remove the call speaker.
    Chiedi a FixBot
    Aggiungi Commento
  16. Samsung Gravity TXT Screen Replacement: passo 16, immagine 1 di 2 Samsung Gravity TXT Screen Replacement: passo 16, immagine 2 di 2
    • Remove the plastic adhesive sheet to expose the ribbon cables
    • The use of an iOpener may be needed to soften the eadhesive
    • Use your finger or a spudger to pull the screen ribbon out of the connector
    Chiedi a FixBot
    Aggiungi Commento
  17. Samsung Gravity TXT Screen Replacement: passo 17, immagine 1 di 3 Samsung Gravity TXT Screen Replacement: passo 17, immagine 2 di 3 Samsung Gravity TXT Screen Replacement: passo 17, immagine 3 di 3
    • Use a Jimmy to separate the screen from the rest of the phone
    • You may need to heat the perimeter of the screen with an iOpener to soften the adhesive.
    • Lift the screen away
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
IUPUI, Team 1-1, Renguette SU 2015 Membro di IUPUI, Team 1-1, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G1
5 Membri
24 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 31
Tutti i Tempi: 1,230
