Salta al contenuto principale
Samsung Gravity TXT Keyboard Replacement
Cosa ti serve
  1. Samsung Gravity TXT Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Samsung Gravity TXT Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Gravity TXT Keyboard Replacement: passo 2, immagine 1 di 1
    • Lift the back cover away from the main body of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Gravity TXT Keyboard Replacement: passo 3, immagine 1 di 1
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Gravity TXT Keyboard Replacement, SIM Card: passo 4, immagine 1 di 3 Samsung Gravity TXT Keyboard Replacement, SIM Card: passo 4, immagine 2 di 3 Samsung Gravity TXT Keyboard Replacement, SIM Card: passo 4, immagine 3 di 3
    • Using your finger, push the SIM Card down and slide out of the slot.
    • Slide the SIM card out enough to grab it firmly.
    • Remove the SIM card away from the phone.
    • Follow the visual on the bottom of the SIM card slot to put the SIM card back in the correct orientation.
    • When sliding the SIM Card back in the slot, make sure the card goes all the way in the slot until it hits the stopper.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Gravity TXT Keyboard Replacement, microSD Card: passo 5, immagine 1 di 3 Samsung Gravity TXT Keyboard Replacement, microSD Card: passo 5, immagine 2 di 3 Samsung Gravity TXT Keyboard Replacement, microSD Card: passo 5, immagine 3 di 3
    • Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
    • The removal of the battery is not required for this operation; therefore, step 3 can be skipped if just replacing the microSD card.
    • After the click, release the microSD card to allow it to pop out.
    • Remove the microSD card from its slot
    • When placing the microSD card back in the phone, make sure the card clicks in place.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Gravity TXT Keyboard Replacement, Plastic Back Frame: passo 6, immagine 1 di 1
    • Remove the six 3 mm #00 Phillips screws in the plastic back frame.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung Gravity TXT Keyboard Replacement: passo 7, immagine 1 di 3 Samsung Gravity TXT Keyboard Replacement: passo 7, immagine 2 di 3 Samsung Gravity TXT Keyboard Replacement: passo 7, immagine 3 di 3
    • Slide the keyboard out.
    • Use a Jimmy to separate a small segment of the plastic back frame from rest of the phone.
    • Starting at the bottom of the keyboard is recommended.
    • Slide an opening pick around the rest of the seam, starting at the gap just created with the Jimmy.
    • You will have to slide the keyboard back in to separate the back frame from the top have of the keyboard slider.
    • Lift the plastic back frame away.
    Chiedi a FixBot
    Aggiungi Commento
  8. Samsung Gravity TXT Keyboard Replacement, Motherboard: passo 8, immagine 1 di 1
    • Remove the two 3 mm Phillips #00 screws securing the motherboard to the front panel.
    • Do not try to pull the motherboad out just yet. The display data cable needs to be disconnected from the motherboad first.
    Chiedi a FixBot
    Aggiungi Commento
  9. Samsung Gravity TXT Keyboard Replacement: passo 9, immagine 1 di 3 Samsung Gravity TXT Keyboard Replacement: passo 9, immagine 2 di 3 Samsung Gravity TXT Keyboard Replacement: passo 9, immagine 3 di 3
    • Use your finger nail to disconnect the display data cable from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  10. Samsung Gravity TXT Keyboard Replacement: passo 10, immagine 1 di 2 Samsung Gravity TXT Keyboard Replacement: passo 10, immagine 2 di 2
    • Carefully lift the main motherboard assembly away from the front panel.
    Chiedi a FixBot
    Aggiungi Commento
  11. Samsung Gravity TXT Keyboard Replacement, Keyboard: passo 11, immagine 1 di 1
    • Take the keyboard off of the phone.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Hussain
Membro da: 07/07/15
147 Reputazione
Una guida realizzata
IUPUI, Team 1-1, Renguette SU 2015 Membro di IUPUI, Team 1-1, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G1
5 Membri
24 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 22
Tutti i Tempi: 562
