Introduzione
If the lenses on your Samsung Gear VR with Controller are blurry, scratched, or damaged, use this guide to replace one or both of your lenses. For this guide, you will need a plastic opening tool, metal spudger, and Phillips #000 screwdriver head.
Cosa ti serve
Push the switch on the right-hand side of the device to separate the cover from the main body.
Pull the cover away from the main device.
Use the metal spudger to press on the three tabs around each of the sockets.
Pull out the lenses with your fingers to remove them from the mask.
